ᐅ How much weight can the KALLAX hold when using heavy inserts?
Created on: 11 Sep 2020 08:32
taule
taule
11 Sep 2020 08:32
Hello everyone, I have a question that has been on my mind for a while, and I would like to hear your opinions: How much heavy use—that is, heavy storage items or loads with high weight and frequent use—can the IKEA KALLAX shelf actually support without compromising its stability and durability in the long term?
I understand that KALLAX shelves are generally designed for moderate loads. However, in my work and hobby area, I often have heavy boxes and equipment that I would like to store in it. Therefore, I am particularly interested in whether there are load limits recommended by the manufacturer and if there are any experiences regarding how the shelf holds up over time under heavy weight—especially with frequent handling, loading and unloading, or moving the compartments.
Maybe someone also has tips on how to reinforce the shelf if you want to store a lot of weight in it. Thanks in advance for your opinions and suggestions!
toril
11 Sep 2020 08:44
The official specifications from IKEA for the KALLAX shelf indicate a maximum load of about 13 kg (29 lbs) per shelf, with a total load capacity of up to 70 kg (154 lbs) depending on the model. These values should be considered as guidelines.
For heavier loads, stability may decrease, and permanent weight can be problematic because the material is made of particleboard, which tends to bend or weaken under excessive weight. Therefore, heavy items should be distributed as evenly as possible rather than placed in a single spot.
Reinforcement, such as adding extra metal brackets or installing a back panel with a stability profile, can help improve stability. However, this involves additional costs and some DIY effort.
Muso4
11 Sep 2020 09:15
toril schrieb:
The official specifications from IKEA for the KALLAX shelf state a maximum load of about 13 kg (29 lbs) per shelf
Honestly, 13 kg (29 lbs)? I think that’s not much, considering many people want to load these shelves quite heavily. Of course, it’s not a heavy-duty shelf, but I know people who put really heavy boxes on them – and if it breaks, it’s always “your own fault.”
You could also argue that IKEA probably designs for the average customer, and those who store anything “heavy” need to look for other solutions.
What I’m curious about: Are there people who have loaded the KALLAX with significantly heavier weights over the years and have experience with damage or sagging? Or is the whole thing more durable than the manufacturer lets on?
cassandra
11 Sep 2020 09:33
It is important to take IKEA’s maximum load specifications seriously, as the KALLAX shelving unit is designed for everyday use and made from medium-density fiberboard.
Continuous overloading often causes metal or plastic connectors to fail or the shelves to sag.
For professional use with heavy loads, I would recommend alternative solutions: metal shelving with higher weight capacity or shelves with solid wood cross braces.
Additionally, checking whether the back panel is properly installed and the floor is level can help reduce minor stability issues.
Traman4
11 Sep 2020 09:51
If you want to store heavy items, carefully check the weight capacity per shelf. 13 kg (29 lbs) per board is the standard. Reinforce the shelving with brackets or use metal shelves.
Layla
11 Sep 2020 10:10
I understand your concern about how much weight your KALLAX can really hold. I’ve faced the same issue myself, with heavy binders and toolboxes on the shelves, and I became unsure due to the load limits. It helps me to regularly check the weight and consider whether heavy items might be better stored in a separate, sturdier piece of furniture.
Maybe you can organize your shelving so that heavier items are placed at the bottom and lighter ones on top, to avoid putting unnecessary stress on the structure. Just a practical tip. 🙂
