I have a Malm bed frame from IKEA that I actually like a lot. However, it often makes noises during normal use, such as when turning over or sitting down – creaking or squeaking sounds that are quite annoying, especially when you want to avoid waking others at night. My question is: How can I make my Malm bed frame quieter without making major changes or expensive repairs? Are there simple techniques, helpful tools, or proven tricks you would recommend to effectively reduce the noise? I look forward to your experiences and tips!
Hello TEORA,
to reduce noise from the Malm bed frame, I first recommend systematically checking that all screws and connections are tightened properly. With IKEA furniture, these often loosen slightly through normal use.
A proven trick is to insert felt pads or thin rubber mats at the contact points between the slatted frame and the bed frame. These dampen movement and prevent friction noises.
It is also worthwhile to oil or treat the wooden parts with clear furniture wax or a special lubricant for wood joints. However, apply sparingly to avoid creating slippery surfaces.
If the budget allows, you can also spray silicone lubricant on any metal connection points, if the frame contains metal parts, to prevent squeaking.
In summary: checking screws, using rubber or felt pads, and lubricating connection points are the most important steps.
At this point, I would like to raise a small critical question that should not be overlooked. Tightening screws can provide a short-term fix, but often it only treats the symptoms rather than addressing the root causes.
This sounds well-structured, but what exact type of noise is actually bothering you? Is it more lateral movement or load-related noises under weight? Depending on this, it could also mean that the durability of the bed frame or slatted base is already compromised, which cannot be resolved with simple measures.
I would therefore add that, in addition to the tips mentioned by roryvin, it is also worth checking whether a repair or replacement of individual components makes sense from an economic perspective. There is no easy answer, but it is important not to settle for just short-term solutions.
roryvin schrieb:
Checking screws, using rubber or felt pads, and lubricating connection points are the most important measures.
Hey everyone 🙂
I used to have a squeaky Malm bed frame too – and yes, it gets annoying over time! My secret tip for making it quieter is a small trick I tried myself: I placed thin pieces of foam rubber between the joints where the wood rubs together. This actually reduced the noise a lot!
My answer: use inexpensive dampening solutions like these. For metal connections, sometimes washing machine vibration pads help if the frame stands on the floor – I put those underneath.
Small helpers, big impact – and you don’t have to buy anything new right away. Just give it a try; it can only get better 🙂
TEORA schrieb:
How can I make my Malm bed frame quieter without major changes or expensive repairs?
