ᐅ How can you bypass energy-saving regulations and avoid bureaucratic hassle?
Created on: 8 Jul 2017 19:26
Farilo
Is it possible to build without following the energy saving regulations?
I want to avoid unnecessary insulation and similar measures. At the same time, I want to maintain the great indoor climate that exists in this building from 1959.
Although it was barely insulated, the house remains completely dry and the indoor climate is excellent.
I am planning to build an extension that fits this outstanding indoor climate. All these modern insulation methods are not helpful in this case.
Does anyone have some kind of exemption from the energy saving regulation and can share how they obtained it?
Thanks in advance.
Thanks in advance.
Peanuts7411 Jul 2017 14:51Primarily, the goal is to make surface temperatures or temperature differences visible.
A well-insulated wall, for example, will be close to the outdoor temperature, while the window is naturally less insulated and therefore appears yellow or red.
This is done in winter, as there are little to no temperature differences visible when it is 25°C (77°F) outside.
Peanuts74 schrieb:
Primarily, the goal is to visualize surface temperatures or temperature differences. A well-insulated wall, for example, will have nearly the same temperature as the outside air, while the window—naturally less insulated—will appear yellow or red. This is done in winter because there are little to no temperature differences visible when it’s 25 degrees outside. Hi Peanuts74,
Ah, okay. Interesting.
What do you actually do with this information, or what conclusions can be drawn when you see the temperature differences during nighttime or cold periods?
For example, let’s say I have a house made of natural stone. We are talking about a wall here, which has no window or anything else!
This natural stone construction “insulates” the house according to energy-saving regulations without additional insulation. This wall appears warm/red in the evening and cold/blue during the day.
What can I conclude from this? For me, the usual takeaway seems to be: “Ah! The exterior wall is red/warm, so you’re just heating the street. In other words, add insulation!” Although everything is actually fine.
Thanks for your patience!
Peanuts7411 Jul 2017 15:33The outside surface of the wall should always be cold in winter.
With thermal imaging (WBK), heat bridges are more easily detected. For example, with Ytong walls, you can see the intermediate floors, even if the edges are insulated, because the (non-insulating) concrete rests on them and the house is not completely "wrapped," like with sand-lime brick and polystyrene insulation.
ah ok. So, let’s summarize:
There is no natural stone option that insulates by itself according to the energy saving regulations.
So you have to combine the stone. Does an air cavity and a second layer of stone count towards that?
And the measurement is taken in the morning... But then the stone wall should be relatively cool and shouldn’t appear red/warm, right?
I feel like I’m going in circles…
