ᐅ How can MALM furniture be made more stable?
Created on: 26 Jun 2020 08:47
Funi56
Funi56
26 Jun 2020 08:47
Some time ago, I bought an IKEA Malm bed and after assembling it, I noticed that it feels quite wobbly under heavy use (for example, when two people move around on it or when getting in and out of bed). I suspect that despite following the instructions, the construction is not fully stable due to the thin furniture panels and the slot-together assembly system.
My specific question is:
How can Malm furniture—especially beds or drawer units—be reinforced to make them more durable for regular use without having to completely rebuild the entire structure? Are there proven methods or materials (such as reinforcements, additional screws, special types of glue, washers, etc.) that significantly increase the firmness of the furniture without affecting its appearance or function?
I am particularly interested in practical tips that are easy for non-experts to apply. Thank you for your help!
Palenar
26 Jun 2020 09:15
A very well-formulated and detailed concern.
Basically, MALM furniture from IKEA is designed to be sufficiently stable for normal use, although this can vary depending on the load and quality of assembly. To improve stability afterward, I recommend especially reinforcing the joints with additional mechanical supports.
1. Check the screws and replace them with longer and thicker ones if necessary. Make sure the threads in the panels are not damaged.
2. Additional metal brackets at the corners can reduce twisting. These should be positioned to remain as inconspicuous as possible, for example, inside the carcasses or underneath bed frames.
3. Using wood glue at the joints reduces play and increases friction between the surfaces.
4. Clamping the parts together with screw clamps during gluing can help assemble the components without tension.
5. Installing cross braces (e.g., made of plywood or solid wood) in heavily loaded areas can noticeably increase overall stiffness.
I would be interested to know whether you assembled the furniture yourself and if screws or dowels might not have been fully or properly installed? This can sometimes cause wobbling.
I look forward to more details so I can offer more targeted advice.
LAURE-TA
26 Jun 2020 10:32
Palenar schrieb:
Check the screws and, if necessary, replace them with longer and thicker ones.
That sums it up quite well. Additionally, I would suggest the following step-by-step tip:
1. Completely disassemble the furniture (if possible) and inspect all screws, dowels, and connectors.
2. Insert washers about 2-3 mm (0.08-0.12 inches) thick at all screw points. This prevents the panels from cracking and increases clamping pressure.
3. It is also recommended to use self-adhesive felt pads or small strips of foam rubber between the connectors to compensate for minor material unevenness that may reduce stability.
4. For bed frames, I recommend reinforcing the middle crossbeam with two diagonal wooden slats. These can be easily attached using wood screws.
5. When gluing, it is best to use waterproof PU wood glue, as it swells slightly when drying and fills any gaps.
Common issue: Simply screwing without glue or additional brackets often leads to wobbling or rattling since wood panels slightly move under load.
A quick note: For drawers from the MALM series, it often helps to support the runners laterally with small wooden blocks to prevent wobbling or tilting in the groove.
Ryker66
26 Jun 2020 12:03
I would simply retighten all the screws and especially reinforce the corner angles with metal brackets. Otherwise, there isn’t much else to do.
Funi56
27 Jun 2020 07:59
Palenar schrieb:
I’m curious if you assembled the furniture yourself and whether any screws or dowels might not have been fully or properly installed during assembly?
Thank you for asking! Yes, I assembled the bed completely by myself following the instructions and, in my opinion, tightened every part correctly. However, there were a few spots where I deliberately did not apply full torque because the material didn’t feel completely solid to me. I suspect that the particleboard could break or become brittle if tightened too much, so I was somewhat cautious.
It would be helpful to know how much the screws should be tightened to achieve sufficient stability without damaging the panels.
Also, I’m interested if there are specific screw types or additional fasteners that could be used as replacements for the original IKEA screws, which might be more durable or effective. Thank you in advance!
BeAndrea
27 Jun 2020 09:41
Funi56 schrieb:
It would be helpful to know how tightly the screws should be fastened to achieve sufficient stability without damaging the panels.
That is an important question and shows practical caution.
As a general rule: screws should be tightened firmly until you feel noticeable resistance, but without applying excessive force, to avoid splitting the chipboard panels. If the material gives way or makes cracking sounds, the torque is too high.
When retrofitting, you can use screws with a larger diameter than the originals, but only if the holes in the wood are not too tight; otherwise, you will need wood drill bits to carefully pre-drill.
Additionally, I recommend using so-called "Spax sheet metal screws" for connecting chipboard and MDF profiles – they offer good holding power and are relatively easy to countersink.
Another tip is to use so-called "furniture connectors" or "connecting fittings," which are also available in small sizes. They can help in particularly stressed areas but should be installed flush so they are not visible or intrusive.
Using washers, as already mentioned, is definitely a good idea. They distribute the pressure better and reduce the risk of breakout.
A small ratchet with torque limitation can also help during assembly to avoid overtightening.
