ᐅ How can soft-close mechanisms be added to Ikea Pax drawers?
Created on: 3 Aug 2021 08:17
Butrusus46
Butrusus46
3 Aug 2021 08:17
I am planning to upgrade my Ikea Pax drawers with a soft-closing system because the current hinges are simply too loud and drafty. My question is: What options and suitable products are available to achieve a quiet, smooth, and cushioned closing for Ikea Pax drawers?
I am particularly interested in systems that are easy to install without having to completely rebuild the drawers. It would also be important to know if there are specific dampers or soft-close mechanisms that are directly compatible, or if it might be better to use universal solutions.
Who among you has experience with this and can offer tips or specific recommendations? Thanks for your help!
nofomu
3 Aug 2021 09:23
for Ikea Pax drawers, you can usually use third-party soft-close dampers that are simply attached to the hinges or drawer slides. Just pull out the drawer, clip in the damper, and you're done.
Sometimes Ikea itself offers retrofit kits, but universal dampers are usually cheaper and work well.
nera59
3 Aug 2021 11:45
Hello Butrusus46,
I can help and describe a way to retrofit your Ikea Pax drawers with a soft-close system:
- Getting materials: Buy soft-close dampers designed specifically for drawer telescopic slides. These are often easy to install.
- Preparation: First, pull the entire drawer out of the guide rail. With Pax, these are usually metal rails where the dampers are clamped on the sides.
- Installation: The dampers are usually attached to the back or inside of the guide rail. Screws are often not necessary, as they snap or clamp into place.
- Function test: Reinsert the drawer and close it gently to make sure the damping works and the drawer closes softly.
An important tip: Make sure the damper is compatible with the direction of movement; otherwise, it won’t work correctly. The damper should also be rated for the weight of your drawer.
In general, retrofit dampers work quite well with Ikea Pax, as long as you’re patient during installation. Sometimes it’s worth investing in the original Ikea soft-close slides if you want to replace the entire drawer slides.
If you want detailed material suggestions, feel free to ask again!
rickey
4 Aug 2021 14:08
Butrusus46 schrieb:
What options and suitable products are available to achieve quiet, soft, and damped closing for Ikea Pax drawers?
I personally found it frustrating at first to deal with the loud slamming of the drawers. My advice is not to stress about retrofitting. I tried different dampers and sometimes it only worked properly after a bit of fine-tuning.
Sometimes the components from the home improvement store are already a good choice, as long as the dimensions roughly match. At one point I was afraid I would have to replace everything, but in the end a simple solution was enough.
It’s worth being patient here and calmly looking at several options. What are your experiences?
Ethan
5 Aug 2021 19:37
I’d like to add that retrofitting soft-close dampers to Ikea Pax drawers depends not only on the choice of damper but also on the exact type of drawer slide used. Ikea uses different models, so compatibility should be checked carefully.
Here is a structured approach:
- Identify the slide type: Open the drawer and measure the slide, noting the type and dimensions. Model numbers are often printed on the inside.
- Select the dampers: Use this information to find a suitable soft-close system. Both specific Ikea replacement parts and universal products might work; the key factor here is the mounting method.
- Installation: Be aware that many dampers can simply be clipped in or secured with small screws. If screws are needed, pay attention to the correct length to avoid damaging the drawer.
- Testing and fine-tuning: After installation, adjusting the damper’s behavior is important. Sometimes a few millimeters of adjustment is necessary to ensure smooth closing.
Finally, a crucial tip: patience during installation is essential — it can take several attempts to get everything running perfectly. If you’re uncertain, it’s better to measure and double-check before drilling or screwing.
I hope this helps you!
