ᐅ How can IKEA Hemnes furniture be made safer for a child’s bedroom?
Created on: 8 Jun 2020 14:37
koron62
koron62
8 Jun 2020 14:37
I would like to start a discussion on the topic: How can IKEA Hemnes furniture be made safer in children’s rooms? Hemnes furniture is very popular due to its design and sturdiness, but there are frequent reports of tipping hazards with tall cabinets and dressers, especially when children climb on them or pull themselves up using the furniture. My question is aimed at everyone in the forum with experience: What practical, safe measures can be taken to make the Hemnes range childproof? I am thinking of possible installation instructions, additional fastenings, or even modifications to the furniture itself. I am also very interested in ideas about certified safety accessories or experiences with corresponding IKEA safety products. What should one pay special attention to in order to prevent accidents without restricting functionality? Thank you in advance for your insights!
LEVI41
8 Jun 2020 15:29
One of the most important safety measures for Hemnes furniture, especially for tall cabinets and dressers, is proper wall anchoring using suitable anchor screws, which IKEA often provides.
- Use only the fastening materials recommended by IKEA or at least equivalent quality to ensure stability.
- Make sure the furniture is placed on a level surface to prevent wobbling.
- For drawers and doors, it is advisable to install child safety locks to prevent accidental pinching.
- As an option, anti-tip safety straps can be used to secure the furniture to the wall.
In addition to mechanical fastening, weight distribution is also important: heavy items should be stored at the bottom to further reduce the risk of tipping.
SETHBLA
8 Jun 2020 16:43
I recommend installing the tilt restraint offered by IKEA.
Additionally: equip drawers with locks and store heavy items at the bottom.
Domau0
9 Jun 2020 10:02
Regarding safety concerns with Hemnes furniture in children’s rooms, a detailed assessment of the tipping hazard is essential. The Hemnes series is primarily made of solid pine wood, which is durable but can tip over if not properly secured. The required wall anchoring using the included hooks and plugs is mandatory, but please pay attention to the following:
- Check the type of wall (drywall, concrete, brick) since the anchoring method must vary accordingly. For example, drywall often requires an additional metal support or a special drywall anchor.
- Verify whether the IKEA assembly instructions include all safety components, or use additional safety straps from a specialized supplier that are rated for higher loads.
- Equip the lower drawers with soft-close dampers and safety catches to prevent children’s fingers from getting caught.
- Avoid storing heavy items in upper compartments.
- Consider applying rounded edge protectors to the furniture to reduce injury risk in the event of falls.
Could you please share information about the layout and construction of your child’s room? This will help determine the appropriate fastening materials.
koron62
9 Jun 2020 11:17
Domau0 schrieb:
Could you please describe the characteristics of your child’s room? This helps in choosing the right fixing materials.
Good question. The child’s room is in an older building with solid brick walls that are plastered. I assume standard wall plugs should work here. I also plan to secure the furniture at multiple points to increase stability. What are your thoughts on installing additional safety straps independently, which IKEA doesn’t provide directly? Are there any experiences with compatible products?
sonplo
9 Jun 2020 12:44
koron62 schrieb:
What do you think about installing additional safety straps yourself, which IKEA does not provide directly? Are there any experiences with compatible products?
Installing your own high-quality anti-tip straps is generally highly recommended, especially in rooms used by children. However, when purchasing, make sure that the straps are approved for child safety and are strong enough to hold the intended load.
Additionally, for Hemnes furniture, you can attach felt pads or non-slip mats underneath to prevent sliding on smooth floors.
If multiple anchor points are possible, this significantly increases safety.
Have you already installed the IKEA wall brackets, or are you planning to add straps in addition to them?
