ᐅ How can IKEA Hemnes furniture be stabilized on uneven floors?
Created on: 24 Apr 2024 20:17
WALTHERRON
WALTHERRON
24 Apr 2024 20:17
I have set up some IKEA Hemnes furniture at home, including dressers and shelves, and I’m facing the problem that the floors in my apartment are not completely level. This causes the furniture to wobble slightly and not stand as securely as it should. I want to avoid any damage to the material underneath or to the furniture itself, and secure stability is especially important for taller cabinets.
So my question to the community is:
What is the best way to stabilize IKEA Hemnes furniture on uneven floors? Which tools or methods are recommended? I have already considered furniture glides, special shims, or adjustable feet, but I would like to know if anyone has experience with this type of furniture, perhaps with practical tips for a more permanent solution.
I would appreciate suggestions that are more than just temporary fixes, and that truly help secure the furniture long term—without affecting the appearance or requiring permanent modifications to the furniture. Thanks in advance!
kulau
24 Apr 2024 21:03
Hello WALTHERRON,
First of all, I want to say that your concern is very clearly expressed and you have described the situation well. Uneven floors can especially cause stability issues with wooden furniture like the Hemnes series made of pine or MDF.
Regarding solutions:
- I recommend first measuring the degree of unevenness precisely, for example with a spirit level or a long straightedge, to fully understand how severe the floor irregularities are.
- Since Hemnes furniture is quite heavy and comes with fixed feet, it is possible to modify or replace the original feet. IKEA itself does not offer adjustable feet for Hemnes.
- A very reliable method is to install adjustable furniture glides made of plastic or metal under the existing feet. These are height-adjustable and allow exact leveling.
- Felt pads can also be applied to protect the floor, but by themselves they don’t help with unevenness unless used together with adjustable feet.
- If the unevenness is significant, consider placing small wooden wedges between the floor and the furniture. Be careful with this to avoid sideways pressure or strain on the furniture.
- Screws with washers are mainly helpful if the furniture legs themselves are slightly tapered or warped, but not for floor unevenness.
Important: Make sure that after adjustment, the furniture is not permanently tilted, as this can cause material stress over time.
What type of floor do you have exactly? Parquet, tiles, laminate? Are there specific spots that are more uneven? This might affect which materials are suitable.
Looking forward to your feedback.
peovin
25 Apr 2024 07:41
In short: Adjustable furniture glides under the legs allow you to precisely adjust the height. Additionally, felt pads protect the floor. This should eliminate any wobbling.
fredle
26 Apr 2024 10:22
I would like to share a brief guide on how to stabilize Hemnes furniture on uneven floors:
1. Floor assessment: Use a spirit level to locate and evaluate the uneven areas.
2. Adjustable furniture glides: These are ideal because they allow flexible height adjustment. It is best to choose models with plastic or metal plates that can be attached under the original furniture legs.
3. Installation: Securely screw the adjustable feet onto the original furniture legs. Depending on the model, you can either remove the old floor protectors or screw the new ones underneath.
4. Leveling: Once all feet are installed, place the furniture upright and adjust the height so that the furniture stands firmly on the floor without wobbling.
5. Optional: Attach felt pads to the furniture glides to protect the floor and improve glideability.
Common mistakes I notice:
- Using only wedges, which often cause uneven pressure and strain the furniture structure.
- No protective material on the feet, which quickly leads to scratches or dents on the floor.
If you want, you can specify the exact furniture models, and I can help with suitable links to adjustable furniture glides. Just a tip: pay attention to the maximum load capacity and the type of attachment, as small screws are often required.
Good luck stabilizing your furniture!
