ᐅ How can IKEA HEMNES furniture be recycled effectively?
Created on: 17 Mar 2022 09:12
sokomeo
sokomeo
17 Mar 2022 09:12
I am currently looking into how IKEA Hemnes furniture can be recycled effectively. The Hemnes series is mostly made of solid pine wood, which seems to be generally recyclable, but I have not found clear information on how to best handle the individual components—such as wooden frames, fittings, and possibly glass or metal parts—in order to reuse them sustainably or dispose of them properly.
Furthermore, I am interested in whether there are proven methods to dismantle these furniture pieces into their materials so they can be used as raw material sources without generating much waste.
Who can share experience or expert knowledge on how to properly dismantle and recycle Hemnes furniture? Are there practical options for private households, or do you need to rely on professional recycling centers?
Thank you for your suggestions!
GiRoyce
17 Mar 2022 09:45
Hello sokomeo,
your question about recycling IKEA HEMNES furniture is very practical. The HEMNES series mostly uses lacquered pine wood, which can generally be recycled, but the lacquer coating is important as it complicates the recycling process.
Basically, I recommend the following steps:
- Completely disassemble the furniture: remove screws, metal fittings, and glass – metal and glass should be recycled separately.
- The wood can usually be disposed of in smaller pieces through local wood waste collection or, preferably, taken to recycling centers that use wood for energy recovery or processing into wood panels (e.g., particleboard).
- For larger, intact pieces, it is worth passing them on as second-hand items since direct furniture recycling often involves a loss of quality.
For private households, disassembly is recommended if you have enough time and tools. Professional recycling centers often accept whole pieces of furniture and then dismantle them mechanically.
I hope this helps you get started!
LOGEMIN
17 Mar 2022 10:08
In addition to GiRoyce’s initial assessment, I would like to provide a brief guide on how to systematically recycle IKEA HEMNES furniture.
1. Preparation:
- Gather tools (screwdriver, possibly a cordless drill, hammer)
- Set up your workspace with a protective covering
2. Disassembly:
- Remove all screws and fittings, especially metal parts such as hinges and handles
- Carefully remove glass or mirror parts
- Sort wooden parts separately (front panels, side panels, shelves)
3. Material separation:
- Take metal parts to a scrap yard or metal recycling facility
- Collect glass separately, as it is recycled differently
- Check wood for damage:
- Undamaged wooden panels may be reusable
- Heavily damaged wood can be chipped and used, for example, as wood chips
4. Utilization:
- Sell or donate intact furniture pieces or parts
- Only burn leftover wood yourself if it has no paint or coatings, since paint complicates technical and environmental aspects
I strongly recommend checking local waste disposal regulations beforehand, as acceptance policies vary.
If you need further details, I am happy to assist.
kogudra
17 Mar 2022 11:23
The two previous posts summarize the key points well. I would like to add that IKEA HEMNES furniture, due to its construction—solid pine wood with metal connectors—is relatively easy to disassemble. For sustainable reuse, especially consider the following:
- Sorted return to certified recycling centers that can specifically process this type of furniture.
- Use in upcycling: for example, repurposing wood scraps as shelves or small furniture pieces like stools.
It is important not to simply dispose of the wood with regular household waste, as it often ends up in incineration plants, losing the potential for material recycling.
Donating to social organizations for repair work is also an option.
One point of caution concerns the paint: some coatings contain harmful substances that complicate composting or incineration.
retau
17 Mar 2022 13:57
Wow, thanks for the great initial responses! I want to emphasize again that recycling doesn’t just mean “throwing away,” but also creative reuse (upcycling) is an awesome solution!
HEMNES furniture is especially suited for this because the material is sturdy and attractive. Some people craft it into coat racks, benches, or shelves.
I believe that reusing furniture through personal projects makes a huge contribution to sustainability!
Does anyone have examples or instructions on how to carefully disassemble or redesign HEMNES specifically for upcycling? I’d appreciate it!
PAUREO54
17 Mar 2022 14:21
It is best to remove all screws, separate metal parts and glass. Take the wood to a recycling center or bulk waste collection. Give away or sell used furniture if it is still in good condition.
