ᐅ How can IKEA Hemnes furniture be arranged to save space efficiently?
Created on: 3 Dec 2020 18:37
ellute
ellute
3 Dec 2020 18:37
I am currently exploring how to arrange IKEA Hemnes furniture in the most space-saving way possible. Since this series is known for its sturdy construction and classic design, the pieces tend to be somewhat larger and are not really designed for small rooms.
My specific question is whether anyone here has experience with arranging the various Hemnes elements (e.g., dressers, shelves, nightstands) in a way that maximizes storage space without making the living area feel cramped.
I am especially interested in tips on the optimal combination of furniture pieces, possible layout patterns, and whether there are any tricks when organizing or setting up that help to use the space efficiently.
What considerations should you start with before arranging? Does anyone have concrete examples or even ideal layout suggestions? I look forward to your knowledgeable contributions!
Guyju
3 Dec 2020 19:12
Hello ellute,
I think starting with an analysis of the available space is very important. For IKEA Hemnes furniture, I recommend the following approach to save space:
- First, define how the room will be used: Where is the most storage needed? Living area, bedroom, or hallway?
- Then assemble the furniture modularly: Hemnes dressers often work well placed next to each other since they usually have similar depths.
- Use doors instead of open shelves to avoid visually overcrowding the space.
- The furniture height should be adjusted to the wall or room height to make the most of the vertical space.
When arranging the furniture, I suggest storing heavy and rarely used items at the bottom, and frequently used items at mid-height. It also helps to consider whether certain Hemnes pieces can be combined, for example, placing a dresser under a shelf to share the floor space.
In summary: measure the space functionally, arrange furniture modularly side by side or stacked, choose door options over open shelves, and pay attention to vertical dimensions.
Many users also make the mistake of spacing furniture too far apart, which leads to unnecessary loss of space.
mabla
3 Dec 2020 21:04
Guyju schrieb:
Many users also make the mistake of placing furniture too far apart, which unnecessarily wastes space.
Exactly, furniture should be placed as close together as possible.
Additionally, use the inside of doors for storage or hooks.
And rather stack items instead of spreading them out over a large area.
cassandra
4 Dec 2020 10:27
As an addition: IKEA Hemnes furniture is mostly made from solid wood-based materials, which requires a certain footprint. However, space utilization can still be optimized by considering the following points:
- Use corners efficiently by placing Hemnes corner cabinets or shelves specifically there.
- Make sure there are no unnecessary gaps between the furniture, as Hemnes pieces often appear bulky due to their material thickness.
- Consider surface usage by adding top shelves to dressers, which increases vertical storage capacity.
I also recommend planning carefully before purchase with a detailed room sketch and scale, and, if possible, using IKEA’s own planning tools (including those specific to Hemnes) to avoid wrong purchases and suboptimal layouts.
When arranging, Hemnes dressers and shelves should generally be placed along the walls to keep the center of the room free and maintain ease of movement.
Guyju
5 Dec 2020 08:51
ellute schrieb:
My specific question is whether anyone here has experience arranging the different Hemnes elements (e.g., dressers, shelves, nightstands) in a way that maximizes storage while keeping the living space from feeling cramped.
Regarding your desire for more storage without a cramped feeling, I recommend a combination of:
- Vertically stacked cabinets or shelves placed on dressers to keep the floor area minimal.
- Sticking with white or light-colored furniture to maintain an open and airy atmosphere.
- A balance of open and closed units to provide storage while keeping a light visual impression.
I have personally experimented with the Hemnes series and found that nightstands fit very well under dressers with open compartments, creating separated zones with minimal space usage.
Additionally, I suggest dividing the room into functional zones before arranging the furniture and positioning the pieces specifically for each area. This way, the layout feels structured and organized even with a high amount of storage.
