ᐅ How can the IKEA Hemnes series be adapted for accessible living?
Created on: 21 Jan 2024 08:37
avdironI am currently focusing intensively on how existing furniture from the IKEA range can be adapted for barrier-free living. Specifically, I am interested in the Hemnes model, which is very popular due to its classic appearance but, in its standard version, is not ideal for people with reduced mobility or disabilities.
My question to the community is: How can the IKEA Hemnes be modified or supplemented for barrier-free living to make daily life easier for people with various impairments? I am particularly thinking about aspects such as height adjustments, handles that offer a better grip, or modifications that allow access for wheelchair users.
Is it possible to redesign the existing furniture through personal efforts or specialized craftsmen, or is it better to completely replace it with furniture specifically designed for barrier-free use? I would appreciate detailed advice, preferably with practical examples or technical tips.
Adapting the IKEA Hemnes furniture for accessible living is a very interesting topic that involves many technical and practical challenges.
First, it should be noted that Hemnes furniture, due to its solid wood construction, is relatively well suited for modifications. For example, height adjustments can be made by unscrewing the legs and replacing them with longer or shorter ones, which can significantly improve access for wheelchair users—such as with dressers or bedside tables. However, it is important to pay attention to the structural integrity to avoid compromising stability.
Next, replacing the handles is an option. Standard wooden or metal handles can be difficult to operate for people with limited grip strength or fine motor difficulties. Ergonomically shaped, larger handles or even handles with soft covers could be installed. These handles should allow for easy operation even with restricted muscle strength.
For cabinets and drawers, installing soft-close hinges and self-closing mechanisms can also be beneficial, as these require less force to open. The importance of smooth-running drawer slides is often underestimated; these can further reduce the effort needed.
Another option is using lever handles instead of knob handles, especially for doors. However, this is not easily implemented on Hemnes wardrobes because their design would have to be modified.
Regarding a fully accessible replacement, it might be worth considering specially designed furniture tailored to local needs in the long term. These are often built with height adjustments, non-slip surfaces, and tactile markings included.
I would be interested to learn more about which specific daily limitations should be particularly taken into account to better align the modifications. For example, the requirements of a wheelchair user with full hand function differ from those of someone with severely limited grip strength.
narDietmar21 Jan 2024 13:57GOLO42 schrieb:
For height adjustments, for example, the legs can be unscrewed and replaced with longer or shorter ones, which can significantly improve access for wheelchair users—such as with dressers or bedside tables.That’s a good point. I would like to add that when changing the height of furniture, one should also pay attention to the clearance underneath in terms of width, so that wheelchairs or other mobility aids actually fit. Often, only the height is considered, but the free space in depth and width is just as important.
Furthermore, I recommend installing easy-to-use, preferably electric opening mechanisms for drawers and doors, if the budget and technical requirements allow. This can greatly enhance independence in daily life.
Such modifications are best coordinated with a carpenter or a specialist in accessible living, as they have experience with the requirements and the material properties of wooden furniture.
I would recommend replacing the handles on Hemnes furniture with longer bar handles. They are easier to grip.
In addition, drawers with soft-close mechanisms should be installed to reduce the amount of force needed.
This is the best way to make the furniture more accessible with minimal effort.
narDietmar schrieb:
I would like to add that when changing the furniture height, attention should also be paid to the clearance under the furniture to ensure that wheelchairs or other mobility aids can actually fit.That is an important point—I hadn’t considered that in detail before, but indeed a simple height adjustment may not help much if the maneuvering space underneath remains limited.
GOLO42 schrieb:
I’m interested to know which specific everyday limitations should be taken into account in order to better tailor the modifications.I’m mainly thinking of people who use wheelchairs and have limited hand function, such as those with spastic movements or reduced strength. This makes operating many furniture pieces in the living environment very difficult.
What types of opening mechanisms would you recommend that are technically straightforward to modify and financially reasonable? Are there practical examples of electric retrofits specifically for Hemnes?
The combination of height adjustment, ergonomic handles, and easy-to-operate opening mechanisms is certainly key to accessibility.
One option is so-called electric push-to-open systems. These replace mechanical handles, allowing you to simply press lightly against the door or drawer. Such systems are usually battery-powered and can often be retrofitted.
Additionally, replacing traditional handles with large, easy-to-grip levers or loop handles is worthwhile, as they also work well with assistive devices.
In the trade sector, there are also modular brackets that can be added for wheelchair users to automatically open cabinet doors, although these tend to be more expensive and complex.
avdiron schrieb:
What types of opening mechanisms would you recommend that are technically straightforward to adapt and also affordable?
