ᐅ How can I enhance the appearance of my Ikea PLATSA furniture?
Created on: 7 Feb 2017 18:23
Mansar
Mansar
7 Feb 2017 18:23
some time ago, I bought several Ikea Platsa units, mainly for my living room wall and hallway. Overall, I am quite satisfied with their functionality, but I find the appearance a bit too plain and monotonous. My question is: how can I visually enhance my Ikea PLATSA furniture without incurring high costs or a lot of effort? I would like to know which simple tricks and materials can make the surfaces or shapes more interesting. Are there any recommendations for paints, handles, lighting, or perhaps special combinations? I would also appreciate hearing about your experiences with modifying or customizing PLATSA. Thanks in advance!
JUHAU
7 Feb 2017 19:07
Hi,
The easiest option is to use interchangeable handles or knobs. They come in many designs, are affordable, and can significantly change the look.
It is also worthwhile to apply adhesive films or wallpaper to the back panels of the shelves. This quickly adds a contrasting color.
TEBILO
8 Feb 2017 08:41
Hello Mansar,
Regarding your question about how to visually enhance the Ikea PLATSA furniture, I would like to offer some detailed suggestions, as I have extensive experience with furniture design and DIY modifications:
- First, surface treatment is very effective. Since PLATSA is usually finished with white or light paint, you can lightly sand it with sandpaper and then repaint it using chalk paint or furniture paint. The process is relatively simple, but I recommend applying a primer first to avoid adhesion problems later on.
- Handles: Replaceable handles are good, but I also suggest considering a combination with magnetic catches, which allow frequently used doors to close gently.
- Lighting: LED strips or small recessed spotlights are suitable for adding accents, especially inside shelf compartments. They highlight both the material and the contents.
- Materials: You might experiment with veneered wood panels or self-adhesive wood-effect films on certain surfaces to create contrasts between modern and natural looks.
- Customization can also be achieved by attaching decorative back panels or by adding glass fronts to open shelves.
I would also be interested to know: Which PLATSA models do you have exactly, and how are they currently assembled? That way I could provide more targeted ideas for modifications.
JONKO
8 Feb 2017 11:16
Mansar, I completely understand how important the visual appearance of the furniture is, especially when it comes to a rather simple series like PLATSA. At first, I also felt that the look was somewhat sterile and then tried to make the furniture more lively with some color and personal details.
TEBILO schrieb:
- First of all, the surface treatment is very effective. Since PLATSA is usually made with white or light paint, you can easily roughen it with sandpaper and then repaint it with chalk paint or furniture paint.
I partly did that as well and found that it not only changes the appearance of the piece but also makes handling it more pleasant, as it creates a certain texture. I didn’t realize this at first, but I noticed that I enjoy “touching” the furniture more because of it.
If you’re interested as well: you can spend days searching for the perfect handles or lighting – but actually, just one well-chosen detail is enough to create a completely new effect. Besides the look, are there any practical requirements that are important to you?
chenlen
8 Feb 2017 13:29
Regarding the visual enhancement of Ikea PLATSA furniture, several technical and functional improvements can be made that significantly affect the overall appearance.
From my perspective, three key aspects should be considered:
- Surface Treatment:
The standard finish of PLATSA is usually semi-gloss and looks quite modern. However, if you want a more customized look, sanding lightly with fine-grit sandpaper is recommended to prepare the surface for a different type of paint or coating. Water-based acrylic paints or matte finishes are especially suitable, as they hardly yellow and are heat-resistant.
- Hardware / Handles:
Replacing the handles is a very effective way to change the style. Handles made of metal or wood with clean lines work best to influence the look deliberately—for example, leather pulls can add a warm, natural accent. It is important to ensure the compatibility of the drill holes, which are usually standardized on PLATSA units.
- Interior Lighting:
Adding LED lighting inside the modules can turn the furniture into an atmospheric feature even at night. The appropriate color temperature is important: warm white creates a cozy atmosphere, while cool white appears more neutral and functional.
Additionally, I would check whether minor modifications to the sliding systems (such as soft-close mechanisms) can be implemented, as these often enhance the perception of quality and design.
If you provide precise measurements and model types, I can offer more targeted recommendations.
