ᐅ How can I protect Malm furniture from moisture?
Created on: 11 Mar 2020 18:27
SARURI65
SARURI65
11 Mar 2020 18:27
I am currently facing the problem of having my IKEA Malm dresser in a slightly more humid room, and I am concerned that the moisture might damage the furniture. Therefore, I would like to know: how can I seal Malm furniture against moisture without affecting its appearance or requiring too much effort?
I imagine that applying some kind of protective layer on the outer surfaces or edges could work, or possibly treating the inside. It is important for me that the solution provides long-lasting protection and does not damage the material, which is made of particleboard with a foil coating.
Does anyone have practical experience or can recommend any products? I would appreciate any tips, including alternatives to direct sealing, such as ways to better protect the furniture from moisture. Thanks in advance!
fepau
11 Mar 2020 19:33
Hey, this is exactly my area of expertise! :-)
SARURI65 schrieb:
How can I waterproof Malm furniture without affecting its appearance or making the work too complicated?
I simply treated my Malm dresser with a matte acrylic clear coat. The finish forms a very thin protective layer over the surfaces that is hardly noticeable but still protects against moisture! The key is to carefully apply the clear coat to all edges – these are usually the weak points.
In addition, I sealed the underside with a thin sealing tape to prevent moisture from seeping in from below. Essentially, an invisible moisture barrier.
Don’t worry, it’s very easy to do and you don’t need to disassemble the furniture!
I recommend the clear coat from XY; it dries quickly and offers excellent protection. Give it a try—it provides peace of mind and saves trouble!
Donar34
12 Mar 2020 08:19
fepau schrieb:
I simply treated my Malm dresser with a matte acrylic-based clear coat.
This is a useful practical tip.
Regarding systematic sealing: Malm furniture is made from a substrate, usually particleboard or MDF, which is covered on the surface with a melamine foil or veneered finish. Moisture can penetrate at the edges because there is no sealed foil edge protection there.
Therefore, I recommend:
1. Carefully sealing all cut edges with a clear coat based on polyurethane or acrylic.
2. Optionally, an additional treatment of the underside with water-repellent agents.
3. Avoid moisture sources as much as possible by keeping some distance from the furniture, for example no direct wall dampness or standing water on the floor.
4. Ensure adequate ventilation.
Avoid aggressive paints or waxes that can damage or cause the material to swell.
This way, you ensure the best protection without altering the appearance.
Tevin
13 Mar 2020 12:47
Donar34 schrieb:
Moisture can penetrate at the edges because there is no sealing film end cap there.
Exactly, that is the key point.
I would like to add that using special edge banding for furniture can also be very helpful. These are narrow strips or edge tape that are applied to the existing edges with heat-activated adhesive. These edge bands are made of plastic and provide an additional barrier against moisture.
Also: before working with varnish or edge banding, make sure the surfaces are clean, dry, and free of grease so the sealing can hold properly.
Regarding the products: clear varnish is good, but you can also try silicone-based furniture impregnators, which are often more flexible and offer good protection with a thinner layer.
If the furniture piece is placed in particularly damp conditions, I also recommend attaching a small spacer or plastic furniture glider under the feet to prevent direct moisture absorption from the floor.
I hope this helps! If you like, I can provide some specific product recommendations.
