I’m planning to upgrade my IKEA Platsa shelves with LED lighting to achieve better illumination and a modern look. I already have a few ideas in mind but am unsure about the best and safest way to implement this technically.
My detailed questions:
- What type of LED lighting is most suitable for the shelves (LED strips, modules, spotlights, etc.)?
- How can I best manage power supply and cable routing to keep everything tidy and neat?
- Are there simple technical solutions for dimmable or controllable lighting (e.g., remote control or smart home integration)?
- Which accessories or tools should I definitely have on hand for installation?
I have basic knowledge of electrical engineering, so I’m confident I can solder or glue myself, but I want to avoid mistakes that could cause problems later. I would be grateful for any guides, tips, or advice.
Thank you in advance!
Flexible LED strips are best suited for PLATSA; you can easily stick them inside the shelf.
Use a power supply with the appropriate adapter and hide cables with cable channels or clips.
For control, there are standard dimmers for LEDs or affordable remote controls, depending on how convenient you want it to be.
Hello kuga8,
I’m happy to help you with a brief guide:
1. LED Lighting Type
- The best option is 12V LED strips with sufficient brightness (at least 300–400 lumens per meter). They are flexible and easy to install.
- Make sure they are dimmable if you want to add a controller later.
2. Power Supply and Wiring
- A 12V power supply with the appropriate current rating depending on the length of the LED strips is essential.
- Use cable ducts or self-adhesive cable clips to neatly route the cables along the shelves.
3. Control
- For simple control: an LED dimmer with remote control.
- For smart systems: controllers with Wi-Fi or Zigbee connectivity (e.g., compatible with Alexa).
4. Installation
- Clean the surface thoroughly before applying the LED strips.
- Keep all connections clean and solder wires if needed for better durability.
Common mistakes I have seen:
- Overloading the power supply, causing the LEDs to flicker or fail.
- Ignoring cable management, which affects the overall appearance.
My tip: Buy at least 10% more LED strips in case you want to expand later.
I hope this guide helps you!
3. Control
4. Installation
jordanvin1 Dec 2020 07:26REPITAR schrieb:
For simple control: an LED dimmer with remote control.Absolutely right! I upgraded my PLATSA shelves with LED strips myself last year, and it was a lot of fun! A dimmable solution really adds a great atmosphere. 😊
Also, with inexpensive RGB strips, you can even change the colors – perfect if you want some variety!
Don’t be intimidated by the installation. Just wire everything neatly, maybe secure it with cable ties, and then enjoy!
Have fun with your project!
Torsten452 Dec 2020 14:59In addition to the tips already mentioned, I would like to add the following:
- When choosing LED strips, it is important to consider the ingress protection rating (IP rating). For indoor use inside furniture, IP20 is sufficient, but if moisture exposure is possible, IP44 or higher would be advisable.
- The power supply should use a certified power adapter to ensure safety and longevity.
- If you plan a smart home integration, I recommend a central control unit that can independently switch multiple zones.
- Pay attention to how much heat the LED strips generate, especially during extended operation, and avoid direct mounting on easily flammable materials without sufficient clearance or cushioning.
These points increase the safety and lifespan of your lighting solution and ensure a professional retrofit.
