ᐅ How can I replace the drawer slides in Ikea BESTA units?
Created on: 6 Oct 2023 08:39
X
Xander32
X
Xander32
6 Oct 2023 08:39
I recently purchased an Ikea Besta furniture unit and want to replace the rollers on the drawers because after some time they no longer slide smoothly and occasionally get stuck. My specific question is: How can I replace the drawer rollers on Ikea BESTA?
I have already tried pulling out the drawers and inspecting the rollers, but it doesn’t seem straightforward, as the rollers appear to be part of the guide rails. Is there a particular method to remove the rollers and install new ones? Do I need to disassemble individual parts or order special Ikea replacement components?
I would really appreciate detailed answers, including tips on what to watch out for to ensure the drawers work smoothly again and maintain their load capacity. Thanks in advance!
Domau0
6 Oct 2023 11:14
Hello Xander32,
First of all: Replacing the drawer rollers in Ikea BESTA units is indeed a bit trickier than with some other furniture lines, as the rollers are often integrated with the drawer slides. The procedure also depends on which type of drawer runner is installed (for example, whether it is a roller guide underneath the drawer or ball-bearing runners on the sides).
In general, I recommend the following steps:
- Pull the drawer completely out of the cabinet. If there is resistance, first release the front locking mechanism (usually small clips or levers on the sides).
- Remove the rollers or drawer slides from the drawer or cabinet. Depending on the model, rollers may be clipped in, screwed in, or inserted.
- If the rollers are clipped in, carefully use a small screwdriver or flat prying tool to release the roller mechanism so the plastic rollers can be removed.
- It’s best to order replacement rollers directly from Ikea, where you can find suitable roller sets for BESTA, as not all rollers from the furniture series are compatible. Important: Order numbers or photos help with identification.
- Install the new rollers, making sure they sit correctly in the drawer slides, otherwise you may experience rough movement or the drawer may come off later.
One quick question: Are the existing rollers just worn out, or are they damaged? Sometimes cleaning and lubricating the roller bearings can help with minor wear before you replace them entirely.
In summary: Patience and careful work are essential. If you like, I can provide more detailed instructions for disassembly once you tell me exactly which model you have (for example, measurements, year of manufacture, type of runner).
Josefane
6 Oct 2023 14:27
I think it’s good that you ask such detailed questions, Xander32, and that Domau0 has already provided very thorough answers here. However, I would like to add a note of caution: Have you really checked whether changing the rollers is the actual solution to the problem?
Sometimes the issue with drawer slides is not the rollers themselves, but incorrect installation, misaligned guide rails, or deformation of the cabinet frame. If you replace the rollers too quickly without diagnosing these factors, the problem might reoccur shortly afterward.
Additionally, for some BESTA models, replacing the rollers is not intended. Ikea sometimes designs the running systems as a single component where the rollers are integrated with the rails. In such cases, you might need to replace the entire drawer slide assembly, which can be more costly.
Therefore, my recommendation is to perform a precise diagnosis first. Check whether the guide rails are mounted parallel and securely, whether the drawers are properly installed (sometimes they can be incorrectly placed on the rails), and whether any foreign objects are obstructing the mechanism. Only after that should you consider replacing the rollers.
This is technically necessary because only then can you confidently determine whether this intervention will actually fix the issue.
KUDAISY
7 Oct 2023 09:03
Hello Xander32,
I’d like to add a simple step-by-step guide on how to replace the rollers in a typical BESTA drawer slide:
1. Fully pull out the drawer.
2. On the sides of the drawer, there is usually a small plastic clip or a tension spring. Carefully release this first using a flat screwdriver.
3. After that, you can remove the drawer slide from the cabinet. Be careful not to lose the mounting screws.
4. The black rollers are attached to the slide. In most models, these rollers are simply pushed in and can be pulled out with a little pressure.
5. Insert the new rollers – make sure they snap exactly into the holders.
6. Reattach the slide to the cabinet and insert the drawer.
Tip: If the rollers are difficult to remove, a bit of silicone spray or a drop of lubricant oil can help free stuck parts. But don’t use too much oil, as it can leave stains.
If you have a model with side rails instead of rollers on the bottom, replacing them is somewhat more complex because usually the entire guide rails have to be changed.
Important: After reassembling, check the alignment carefully. Misaligned drawers can damage the mechanism over time.
Good luck!
loken
7 Oct 2023 12:50
KUDAISY schrieb:
If the rollers are difficult to move, a little silicone spray or a drop of lubricant oil can help to loosen stuck spots. But be careful not to use too much oil, or you’ll get grease stains.
I can only confirm that! I had the same issue with my BESTA drawer – after applying some lubricant, the drawers slid smoothly again. Sometimes we forget that a full replacement isn’t always necessary.
A funny anecdote: I once tried to forcefully pull the rollers off – that caused more damage than it helped. So it’s better to proceed gently at first.
And if you order new rollers, make sure to get the original Ikea parts – they often fit better than universal rollers. This keeps the stability intact and prevents squeaking.
One more tip: When reinserting the drawers, lift them slightly before putting them back in, which reduces rattling afterwards. I always use this little trick for my BESTA shelf with drawers.
Good luck, and feel free to share how it went!
