ᐅ How can I repair scratches on BILLY surfaces myself?
Created on: 15 Mar 2021 09:37
biraleo
biraleo
15 Mar 2021 09:37
I recently noticed that some of my BILLY shelves from Ikea have small scratches on their surfaces. Since these shelves are quite affordable and I would rather not replace everything or use professional repair services, I’m wondering: How can I repair scratches on BILLY surfaces myself?
I’m especially interested in tips and methods that are easy for beginners to apply, without needing special tools or expensive materials. It would also be helpful to know if there are differences in treatment depending on the type of material (e.g., laminate vs. veneered wood surfaces), and how to make the repairs as invisible and long-lasting as possible.
I look forward to your knowledgeable advice!
nera59
15 Mar 2021 10:12
Hello biraleo,
first of all, here are some basic tips on how to repair scratches on BILLY surfaces yourself. Since BILLY shelves usually have a melamine resin or laminate coating, they behave differently from solid wood or veneered surfaces.
1. Minor scratches (surface level): You can use so-called furniture markers (available in furniture and hardware stores). It is important that the color exactly matches the shelf.
2. Deeper scratches: If the damage goes deeper into the coating, repair kits with filler putty are useful. This requires some care:
- Clean the surface,
- apply the putty thinly,
- after drying, lightly sand and then retouch with matching paint or varnish.
3. Alternative home remedies: Some users report that polishing with wax or a paste made from walnut oil can visually conceal minor scratches to some extent.
A common mistake is treating the scratch too broadly or using the wrong sanding materials, which can cause more damage. So it's better to proceed carefully.
In summary: Use furniture markers for small scratches and repair kits for larger ones. I hope this helps you!
AUSTINREN
15 Mar 2021 13:46
nera59 schrieb:
Use furniture repair markers for minor scratches, repair kits for larger damages.
Very accurate. To clarify: BILLY surfaces mostly consist of engineered wood with a melamine resin coating or laminate foil. These surfaces are sensitive to mechanical damage, so repairs are usually cosmetic.
A proven method is using special repair wax sticks, with colors matched to common surface finishes. These sticks are rubbed into the scratches and then polished with a soft cloth to blend the finish.
For deeper damage, filling wax can be applied in several layers and sanded between applications. However, this requires some practice.
Unlike solid wood surfaces, aggressive sanding or repainting should not be performed on BILLY, as the thin melamine layer is not repairable.
In short: precise color matching, careful application, and polishing are essential. Professional repair kits for laminate can also be helpful. For very large damages, replacing the affected parts is recommended.
KAUDRA62
16 Mar 2021 08:03
Hey biraleo and everyone else who might be staring desperately at scratches right now! 🙂 I once had a similar “battle zone” on my BILLY shelf and tried a repair kit that looks like wax. I was advised to gently rub the wax into the scratch with light pressure and then polish it with a soft cloth – it really works like a bit of magic!
Be careful not to apply too much, or it ends up looking like sticky chewing gum spread around. 😉 When matching the color, don’t hesitate to experiment a little, as the shade is really important.
What I also find great: for tiny scratches, you can try lightly polishing with furniture polish – just see if the scratch fades a bit. It’s not a 100% fix, but it definitely improves the appearance.
If you want to get really creative, you can use colored wood markers or even permanent markers in matching tones to disguise the smallest damages. It might sound odd at first, but trying it won’t hurt. Good luck! 👍
Surela
17 Mar 2021 17:21
biraleo schrieb:
I’m looking forward to your expert advice!
To address your question in more detail, biraleo: Repairing scratches on BILLY shelves largely depends on the surface material, which can vary between different models. Typically, it is a chipboard base with melamine or foil coating.
My suggestion is a two-step process:
1. Preparation: Clean the damaged area with a mild detergent to remove dirt and grease. Then, allow it to dry thoroughly.
2. Treatment:
- For minor, shallow scratches, I use specialized furniture waxes or repair markers, chosen to match the color tone. These are applied directly into the scratch and gently polished with a lint-free cloth.
- For deeper cracks, I work with a color-matched acrylic filler putty, which is carefully smoothed after drying. Fine sandpaper (grit 240-320) is recommended here to avoid damaging the surface.
An important note: Melamine or foil coatings are synthetic and sensitive to aggressive sanding or inappropriate cleaning agents. Therefore, always handle polishing or abrasive materials with care.
As mentioned before, walnut oil can also help with very fine scratches – the idea is that the oil slightly swells the wood fibers, visually filling the scratch. However, this method is not permanent.
Finally, I would ask: How large are the scratches approximately, and how visible is the damage to the coating?
This information would help me provide you with an even more targeted recommendation.
