ᐅ How can I repair Malm dressers cost-effectively?
Created on: 5 Feb 2020 08:23
NEAL-GAU
NEAL-GAU
5 Feb 2020 08:23
Hello everyone, I have a Malm dresser from IKEA that unfortunately shows some signs of wear: scratches, a small chip in the finish on one corner, and the door doesn’t close properly. Since I don’t want to spend too much money unnecessarily, I would like to know how to repair these kinds of damages myself in a cost-effective way. Do you have any tips on suitable repair products or methods, especially on how to restore the surface to a decent condition and possibly adjust the hinges slightly? Many thanks in advance for your answers!
Ryder35
5 Feb 2020 09:07
For small scratches, you can touch up with a wood repair marker in the matching color. At the corner, fine sandpaper often helps, followed by acrylic paint. Simply tighten or adjust hinges, as they are usually adjustable.
fasefar
5 Feb 2020 11:51
That's great that you're tackling it yourself! 🙂 For the surface, you could try furniture polish or special repair paste for wood—they do a great job of concealing scratches! And for the hinges, try a little graphite powder for light lubrication; it lasts without leaving oily residues. Keep us updated—you’ll definitely do a great job!
NEAL-GAU
6 Feb 2020 07:45
Thanks, that sounds good so far. But I’m wondering if wood repair markers make sense for coated panels like the MALM dresser? The panel is melamine-coated, not solid wood.
fasefar schrieb:
For the surface, you can also try furniture polish or special repair paste for wood; they hide scratches really well!
Is there an affordable product you’d recommend for this, without having to buy a full repair kit? (I don’t want to invest too much.)
And regarding the door: What would you suggest for the hinges if the screw holes have become slightly stripped? Re-screwing would be expensive – are there any tricks?
barEsperan
6 Feb 2020 08:30
Repair pens usually don’t work well on melamine-coated boards because the surface is too smooth. It’s better to use a fine abrasive pad and apply a thin layer of clear varnish.
For stripped screws, it helps to insert small wood chips or toothpicks into the hole before reinserting the screw. This provides a secure hold again, and is inexpensive and quick.
posin50
7 Feb 2020 10:14
Hello! 🙂 I had exactly the same problem with my MALM chest of drawers! I filled small scratches with colored wax paste, which is also quite affordable online. For the door, I lightly refinished the hinges with very fine sandpaper and then used graphite powder, which really helps and costs almost nothing!
barEsperan schrieb:
For stripped screws, it helps to put small wood chips or toothpicks into the hole, then insert the screw.
That also worked great for me, really clever.
