ᐅ How can I best align the doors on an Ikea PAX wardrobe?
Created on: 15 Jun 2023 08:37
Koduken
Hello everyone, I recently assembled an Ikea PAX wardrobe and am now facing the challenge of aligning the doors perfectly. My specific question is: How can I precisely adjust the hinges on the Ikea PAX doors so that the doors close completely flush and align perfectly while still opening smoothly? I have already found the screws on the hinges but am unsure if there is a particular order or tolerance to follow. Are there also any tips for readjusting the doors afterward in case they shift slightly due to frequent opening and closing? I look forward to your detailed advice and experiences.
GALENKU
16 Jun 2023 09:47
One more quick tip for adjustment: You should adjust the doors slowly and systematically, closing the door periodically to check if it is aligned properly. Turning the screws too quickly or drastically usually leads to frustration rather than the desired result.
sarlo
17 Jun 2023 10:05
Hello Koduken, to properly align the doors of an Ikea Pax wardrobe, it’s helpful to carefully study the included manual. It usually even has small illustrations next to each screw showing what effect each screw has. If you’ve already done that, here are a few additional tips:
- Use a spirit level to make sure the wardrobe is standing perfectly straight.
- Open the doors fully while adjusting the hinges; this makes fine-tuning easier and helps you better see the effect of the screws.
- If your doors close unevenly, sometimes a combination of adjusting the hinge screws and modifying the back panel helps, since the back panel can also cause stress.
Speaking from experience, patience definitely pays off here.
loken
17 Jun 2023 14:27
I know all too well how it is with PAX doors – a little tightening here, some adjustment there, and suddenly they look like new! 😄
Here’s a little tip from me: once you have your doors properly aligned, you can secure the hinge screws with a drop of clear nail polish. This helps prevent them from loosening again due to frequent opening.
Also, a small amount of lubricant on the hinge joints often brings back that famous “like new” feeling when opening the doors. This way, you have both appearance and function on your side. Good luck with the adjustments!
