I am planning to use an Ikea Platsa shelving unit, which I currently have in my living room, outdoors in the future – specifically on a covered terrace that is partly exposed to wind and weather. So, my question is: how can I prepare the Ikea PLATSA for outdoor use to ensure it lasts as long as possible and withstands changing weather conditions?
I understand that the material of the PLATSA series is not designed for outdoor use, so I am mainly interested in recommended protective measures to shield the wood and surfaces from moisture, UV exposure, and temperature fluctuations.
Has anyone had experience with treating PLATSA or similar Ikea furniture for outdoor use? What types of impregnations, paints, sealants, or other protective treatments do you use? Should I sand or prime the furniture beforehand? And are there any special assembly tips to prevent warping or mold caused by moisture?
I would greatly appreciate detailed suggestions, personal experiences, or warnings about mistakes I should avoid. Thank you very much in advance!
Hello Kopar,
this topic is indeed very important because IKEA furniture like PLATSA is not designed for outdoor use, and the material is quite sensitive to moisture. Here is a detailed overview of how to best prepare such furniture for outdoor use:
- First, if possible, completely disassemble the furniture. This allows you to access all surfaces and edges easily.
- Sanding: Lightly sanding the surfaces is highly recommended so that primers or paints adhere better. Use fine sandpaper (e.g., grit 120-220).
- Primer: Apply a suitable water-repellent wood primer (e.g., exterior wood primer) to reduce moisture absorption.
- Sealing: After the primer, apply a UV-resistant weatherproof varnish or exterior wood stain. These protect the surface from moisture and UV radiation.
- Pay special attention to edges: Since moisture enters most easily here, edges can be treated with additional sealant or coated twice.
- When reassembling, try to ensure that there is air circulation between the back panel/bottom and the ground. Direct ground contact promotes moisture absorption and mold growth.
It is important to use only products that are explicitly designed for outdoor use! Regular interior paints are not sufficient. It also makes sense to reapply the treatment regularly (every 1-2 years) to maintain protection.
I have personally treated furniture of this kind with multiple layers of stain before and had good results. Of course, it remains somewhat of a compromise since the material is not inherently weatherproof. If you have any questions or want any steps explained in more detail, feel free to ask!
Good morning Kopar,
I would like to add to koneo’s response and provide you with a structured step-by-step guide that is suitable for preparing PLATSA furniture for outdoor use:
1. Disassemble the furniture and clean the surface – thoroughly remove dust, grease, and other contaminants.
2. Sanding – use 180-grit sandpaper to roughen the surface and slightly round off all edges. This improves the adhesion of the coating.
3. Priming – I recommend a primer specifically designed for exterior wood with deep penetration.
4. Moisture protection – apply a water-repellent wood preservative that is breathable to prevent the wood from suffering due to lack of air circulation.
5. UV protection – some wood preservatives already contain UV protection, otherwise a clear UV protective varnish is recommended as a final coating.
6. Pay special attention to joints and edges: it is advisable to apply the primer and preservative in two coats here.
7. Assembly – do not place the furniture directly on the ground. Use small spacers or feet to allow air circulation underneath.
8. Maintenance – check the surface every 1-2 years and re-treat if necessary.
Common mistakes I have observed with this application:
- Insufficient sanding causes poor adhesion.
- Using standard interior paints that trap moisture encourages mold growth.
- No clearance from the ground increases the risk of rot.
Following these points should help you achieve a reliable result. If you want advice on specific products or brand recommendations, I’d be happy to provide that as well.
SUDAN schrieb:
6. Pay special attention to joints and edges: it’s worthwhile to apply the primer and glaze in two coats.I can only agree with that!
Some time ago, I had a similar project and treated everything with wood preservation glaze, but only applied one primer coat. After the first winter outside, I noticed that moisture especially penetrated the edges and the paint began to peel. That was quite frustrating.
What I learned from this is that patience during application is crucial. And as already mentioned, keep the furniture off the ground and don’t forget weather protection if possible.
I’m not a professional, but for me, this was a very instructive process showing that it’s not enough to just quickly paint the furniture. It takes time and care.
What I’m still curious about: Has anyone had long-term experience with how durable PLATSA remains under truly variable weather conditions if it’s treated properly?
