Hello everyone, I’m planning to paint some of my IKEA Hemnes furniture using stencils to give them a custom look. I want to achieve durable results that won’t easily peel or smudge since the furniture is used frequently. I’m especially interested in the proper preparation steps, which paints work best, and how to apply and fix stencils most effectively on the often slightly textured wooden surfaces to ensure clean paint application. Do you have any tips on choosing the right materials (e.g., acrylic, enamel), surface preparation (sanding, priming), and techniques for neat painting with stencils? I would appreciate it if someone could share their experience or even a step-by-step guide. Thanks in advance!
Preparation is key. Sand the furniture thoroughly, then remove all dust. For Hemnes, I always use acrylic paint combined with a polishable clear coat. It’s best to fix stencils with painter’s tape or masking tape and apply the paint by dabbing rather than brushing to prevent any bleeding.
Your question is right on point when it comes to DIY furniture finishing. I would recommend first lightly sanding the surface evenly with fine sandpaper (grit 220 to 320). This significantly improves paint adhesion. Next, clean the surface thoroughly with a solvent like isopropanol to remove any grease or residues that could affect the primer and paint.
For priming, use a special acrylic-based wood primer. This ensures a perfect bond for the paint layer and prevents the wood from swelling. Regarding paint, I suggest using high-quality acrylic paints, as they are flexible, provide good coverage, and are durable—ideal for everyday use.
It’s best to create stencils from self-adhesive film or apply a light spray adhesive to the back, so the stencil doesn’t shift during application and you get sharp edges. When applying the paint, use a sponge or a stippling brush, since a regular brush tends to produce uneven edges. It’s important to pick up only a small amount of paint and apply several thin layers rather than one thick coat.
After painting, sealing with a matte or satin acrylic varnish is recommended. Apply it with a fine varnish brush or a foam roller. Also, I’m curious: what type of furniture surface are you working with exactly? Are the surfaces completely smooth, or do they have any carved or profiled lines? This will also influence the choice of stencil technique.
kaubi schrieb:
Also, I’m curious: What type of furniture surface do you have exactly – are the surfaces completely smooth, or are there also profiled lines?Good question! The Hemnes series mostly has relatively smooth surfaces, but the frames and doors do have some slight profiling, meaning gentle edges and curves. So, I would be working on both flat and slightly textured areas. For the flat surfaces, I’m pretty confident that stencils would work well, but I’m still unsure whether that would be successful or messy on the profiled sections. Are there any special tips for applying paint cleanly along the edges? Or would it be better to stick to freehand painting on the profiled surfaces?
Hello! I’m familiar with your challenge of working on slightly profiled surfaces. For flat areas, traditional stencils work perfectly, as mentioned earlier, using light fixing and a dabbing application technique.
Stencils can also be used on profiles, but the edges often appear less sharp because the stencil does not sit flush. In this case, I would recommend a flexible stencil made of thin vinyl that can bend slightly. Alternatively, you can shape stencils to the edges using fine painter’s tape.
For especially clean edges along the profiles, it helps to touch up with a small, narrow round brush and minimal paint.
Important: It’s best to test the technique first on a hidden spot or a similar surface.
Regarding durability: After painting, protect the surface with several thin layers of clear acrylic varnish. This step greatly extends the longevity of the paintwork.
If you like, I can also share some tips on proper sanding and choosing the right primer.
