ᐅ How can I repaint Ikea Hemnes furniture myself?
Created on: 26 Sep 2021 14:37
chinedu53
chinedu53
26 Sep 2021 14:37
Hello everyone, I recently purchased the IKEA Hemnes furniture series and would like to paint it myself to create a personalized and durable finish. I understand that IKEA furniture usually comes with a primer or coating that may need to be sanded or treated before applying a new paint layer. Therefore, I have a few questions:
- What is the best way to prepare the surface of Hemnes furniture to ensure good adhesion of the new paint?
- Which type of paint is most suitable for MDF or solid wood, as used in Hemnes?
- Are there any special techniques or tools that make painting easier and improve the final result?
- What are the most common mistakes when painting IKEA furniture, and how can they be avoided?
I have some experience with wood painting but I am not a professional. I want to achieve an even and long-lasting paint finish, without unsightly color variations or peeling. I look forward to your tips and experiences!
Palenar
26 Sep 2021 17:44
Hello chinedu53,
Your question is very well formulated and important, as IKEA furniture like Hemnes, which is often made of painted solid wood or MDF covered with a plastic foil, presents some challenges when it comes to painting.
First, regarding preparation: You should thoroughly clean the furniture, ideally with a mild degreaser or denatured alcohol, to remove dirt, dust, and grease. After that, sanding the surfaces is essential to ensure that the new paint adheres well. Use fine sandpaper, around grit 220 to 320. If the surface is a particularly smooth plastic foil, you should start with slightly coarser sandpaper (e.g., 180 grit) to lightly roughen the foil.
About the paint itself: For Hemnes furniture, I recommend water-based acrylic paints or polyurethane (PU) paints suitable for furniture. These are durable and easy to work with. Make sure the paint is approved for interior use and offers good coverage as well as flexibility.
Tools: Brushes can leave streaks; that’s why I prefer a foam paint roller or even a good spray gun attachment (if you have the proper equipment and ventilation). When rolling, be careful not to apply too much paint to avoid runs.
Common mistakes include:
- Insufficient or uneven sanding, which weakens adhesion.
- Applying paint layers that are too thick, causing runs or blistering at the edges.
- Painting in conditions of too high humidity or too low temperatures, which leads to drying problems.
Additionally, test the paint and method on an inconspicuous spot or a sample piece to see how the color and surface react.
I would also be interested to know whether you plan to completely disassemble your furniture and paint the parts separately, or if you intend to treat the furniture in its assembled state? This can affect your working method and the final result.
kemeo68
27 Sep 2021 09:15
Palenar schrieb:
Common mistakes:
- Applying paint layers that are too thick, causing runs or bubbles at the edges.
- Painting in conditions with too high humidity or too low temperatures, leading to drying issues.
I see it a bit differently. Overemphasizing sanding and fearing mistakes often leads people to spend endless time and patience, even though the piece remains just a mass-produced IKEA item in the end. Of course, proper sanding and suitable paints are important, no doubt about that.
But I always wonder: does the piece actually become that much better because of it? Or are we just wasting a lot of time? My theory is that the decisive factor isn’t perfect preparation, but rather the paint itself and how well it matches your interior design.
Also: why not just be bold and cover the furniture with chalk paint or blackboard paint? That gives it a completely new character, even without extensive sanding. If the result starts peeling after a few months, you can still easily sand it off and redo it.
In the end, it’s all about aesthetics, and if you pick the right color, you can easily mask the ‘IKEA look’ without struggling forever with the universally recommended preparation.
fikeo
27 Sep 2021 20:03
Hello chinedu53,
I want to support your concerns about painting Hemnes furniture, but also offer some practical tips to make the process easier.
1. Preparation:
- Completely disassemble the furniture so you can work evenly on all surfaces.
- Clean the furniture thoroughly with a mild cleaning agent.
- Sanding is important: start with a sanding pad or fine sandpaper (180-220 grit). This removes the old paint or finish and improves adhesion.
2. Primer:
- Use a good adhesion primer specifically designed for wood and MDF. This is key for a durable result.
3. Painting:
- Acrylic paint works very well as it has low odor and is available in many colors.
- Apply the paint in several thin coats, allowing each to dry completely.
- Use brushes and small foam rollers to avoid brush marks.
4. Finishing:
- After painting, you can lightly sand the surface between coats with fine sandpaper (320 grit) to achieve a smooth final layer.
- Sealants are usually not necessary with water-based paints unless you want extra protection.
I have personally painted several Hemnes pieces this way, and the results are long-lasting and look very professional.
If you have any specific problems or questions about the materials, feel free to ask!
