ᐅ How can I best utilize and organize the storage space in Ikea Hemnes furniture?
Created on: 19 May 2020 18:23
V
VintarHello everyone, I am currently considering how to make the most efficient use of the storage space in my Ikea Hemnes wardrobe and organize it without making it cluttered or impractical. My main challenge is that the interior space is partly difficult to adjust due to the fixed shelves, and I have a wide variety of items – ranging from clothing and books to smaller household accessories. I am especially interested in tips for systematic compartmentalizing, possible additions such as boxes or inserts, and of course a sensible arrangement that makes access easier. Does anyone have experience with clever solutions that also help save space and maintain order? Suggestions for durable organizing aids or modifications to the furniture itself would also be greatly appreciated. Thank you in advance!
The Hemnes wardrobe does have fixed compartments, which limits flexibility somewhat. For optimal use, the following approach is recommended: - First, sort items by type and frequency of use. - Smaller items fit well into sturdy storage boxes or baskets, ideally stackable. - Flat boxes or drawer inserts placed under the shelves work well for clothing. - Arrange books vertically, using bookends if necessary, to save space. - Maximize vertical space by adding small shelves or intermediate boards, if possible. - Labels improve organization and make handling easier. - Reserve areas with high access frequency at the front or at eye level. These recommendations are based on practical standards for interior design and space utilization. It is important to define your own storage priorities to choose the best solution.
I would like to add a step-by-step guide on how to optimally organize the Hemnes storage unit: 1. Inventory: Lay out all items outside of the cabinet and group them by category. 2. Prioritization: Determine which items are used frequently and which are seldom needed. 3. Planning the layout: Use boxes, inserts, or baskets for smaller objects. Ikea offers suitable organizers, or you can choose universal storage solutions that fit. 4. Installing the inserts: Place boxes so they match the existing shelves—this saves space and prevents clutter. 5. Using the inside of the doors: Often, hook rails or small hanging shelves can be attached to the inside of the Hemnes cabinet doors, for example, to store cleaning supplies or accessories. 6. Labeling: Each box or basket should have a label to help find everything faster. 7. Regular maintenance: Review at least once per quarter and remove unnecessary items. Common mistakes I often see are unorganized stacks or overfilled compartments, which do not effectively save space. In summary: systematic organization and appropriate storage solutions are key to success.
Genevieve20 May 2020 14:58It is interesting how many users simply assume that storage systems like boxes and baskets work automatically. However, I wonder: Are these solutions truly optimal in every situation? The fixed shelves are a major obstacle in the Hemnes wardrobe, yet there is little discussion about whether and how they can be modified, for example through conversions or alternative inserts. It might be more effective to question the physical structure of the wardrobe itself, instead of focusing solely on storage accessories.
sihau schrieb:– How exactly is that supposed to work? Does Ikea officially offer such additional shelves, or do people build their own? Also: What about stability? In my experience, the maximum load capacity of shelves is a critical factor that is often overlooked. Wouldn’t it be more sensible to check the structural integrity first before stacking fully loaded boxes on extra shelves? Alternatively, one could consider limiting the wardrobe’s use to a specific function, instead of trying to fit everything into a single unit. In my opinion, that significantly improves overall organization.
Maximize vertical space by adding small shelves or intermediate boards where possible.
I find the discussion here very interesting, so I would like to add some details from my experience with different Hemnes versions. Basically, the Hemnes wardrobe is made of fairly sturdy solid wood, but the main shelves are fixed in some models, which makes repositioning difficult. However, there are retrofit hole rows on the side panels that allow you to install additional shelves yourself, provided they were not missing from the factory. - Step 1: Make sure to check if your model has these holes for extra shelves. If not, you can carefully and precisely drill appropriate holes, but this should only be done with the right tools and experience. - Step 2: Using sturdy, flat boxes or baskets of standardized height is recommended here. This way, you can make optimal use of the space between the fixed shelves without wasting vertical space. - Step 3: For organizing, I suggest combination solutions: shallow acrylic boxes for frequently used clothes and stackable fabric baskets for less-used items. Consider weight and accessibility when doing so. - Step 4: The inside of the doors often receives little attention but offers additional storage space for small items with hooks, magnetic boards, or small shelves. - Step 5: Before regular use, always check the maximum load capacity of the shelves (usually 15–20 kg (33–44 lbs)) to prevent lasting damage. Finally, a question for you: What items do you primarily want to store? Is it mostly clothing or a mix with other household items? This greatly influences the best organization structure.
