ᐅ How can I make Malm furniture more stable?
Created on: 20 Feb 2015 11:23
garner43
garner43
20 Feb 2015 11:23
Hello everyone, I am planning to make furniture from the Malm series by IKEA more stable and durable, as I have noticed that especially larger drawers tend to lose stability over time and their load capacity is somewhat limited. My question to the community is: What practical and effective measures can you recommend to reinforce the construction of Malm furniture? I am particularly interested in reinforcements that can be integrated well without affecting the appearance, as well as any craftsmanship tips to make the drawers and rear panels more robust. Has anyone had experience with additional inserts, stronger screws, corner braces, or alternative materials? Looking forward to your suggestions!
Fareo65
20 Feb 2015 13:57
garner43 schrieb:
My question to the community is: What practical and effective measures can you recommend to make the construction of Malm furniture more stable?
As a basic step, it is advisable to first check all existing joints for tightness: Loose screws or connecting fittings should be tightened or replaced.
A very effective method, especially for drawers and back panels, is reinforcing the load-bearing elements with additional metal brackets or wooden strips on the inside. Using a generous number of screws for fastening helps improve load distribution and durability.
For drawers, you might also consider replacing the rows of holes for the drawer slides with stronger slides or increasing torsional rigidity by adding internal strips.
Replacing the thin MDF back panel with thicker plywood or multiplex can also significantly improve stability. Careful cutting and precise installation are important here.
In short: A noticeable increase in sturdiness can be achieved by combining firmer screw connections, brackets, and additional, more durable materials.
GLALEO
21 Feb 2015 09:12
It’s great to see this question being discussed here! 🙂 Recently, I reinforced a Malm nightstand with two additional angle brackets inside – it made a huge difference!
Fareo65 schrieb:
A very effective method, especially for drawers and back panels, is strengthening the load-bearing parts with extra metal brackets or wooden strips on the inside.
Absolutely right! Personally, I also think you don’t have to compromise too much on the appearance if you choose small, discreet brackets. It’s also important not to use screws that are too large to avoid splitting the material of the furniture panels.
Additionally, if you have some DIY skills, you can add extra crossbars at the back to hold the carcasses together and greatly reduce twisting. That’s how I made my small Malm chest of drawers really stable! It’s fun and very satisfying. 🙂
biel33
21 Feb 2015 11:37
Hello, I completely understand how frustrating it can be when furniture isn’t as sturdy as you would like. Especially with the Malm series, I’ve noticed that the lightweight construction has its limits, particularly when the pieces are heavily loaded or moved around.
garner43 schrieb:
What practical and effective measures would you recommend to make the construction of Malm furniture more stable?
I would suggest not neglecting the alignment and the floor surface when reinforcing the furniture. Small unevenness in the floor often causes stress and wobbling. Rubber pads under the legs can often help a lot.
GLALEO schrieb:
If you have some DIY skills, you can also add additional cross braces at the back to hold the carcasses together and greatly reduce twisting.
I fully agree with that. Ultimately, the stability and service life of furniture like this depend on several factors—not just the material, but also maintenance and correct assembly.
I’ve also experimented a bit with dowel reinforcements that make the internal joints stronger. That might be worth looking into if you don’t mind the extra effort. Overall, your approach with brackets, better screws, and stronger back panels sounds like a proven method.
