ᐅ How can Malm furniture be made more stable with minimal effort?
Created on: 8 Oct 2024 09:27
Johnatan
Johnatan
8 Oct 2024 09:27
Hello everyone, I have some IKEA Malm furniture at home that unfortunately feels a bit wobbly. Since I don’t want to spend a lot of time or money, I’m looking for simple and cost-effective tips to improve the stability of the furniture. I’m especially interested in methods that don’t require much time or special tools but still make a noticeable difference, such as different screw techniques, reinforcements, small additions, or simple tricks. Does anyone have experience or ideas on how to make Malm drawer dressers or nightstands more stable without much effort?
juMira46
8 Oct 2024 09:34
Hey Johnatan! It’s great that you brought this up – flat-pack furniture really isn’t the most durable when you want to put some strain on it. 😅 My favorite tip: reinforce drawers and the cabinet structure from the inside at key points with small brackets (for example, metal angle brackets you can get at a hardware store). Usually, you use 4 screws, it doesn’t take long, and it’s super effective!
Also, applying a very light thread-locking adhesive to the Phillips screws helps keep them from loosening quickly, so everything stays nice and tight. 🙂 A few felt pads on the furniture legs can also improve stability by reducing indirect wobbling. Good luck!
GALEO4
8 Oct 2024 09:45
Hmm, honestly, I think it’s an illusion that the Malm series could be more stable. These pieces from IKEA are generally designed for short-term use – no tricks will help if you need to accommodate children or store heavy items.
Most of it is particleboard with a thin veneer. I would recommend switching entirely to solid wood instead of trying a “quick fix” here. Sorry, that’s probably not what you want to hear, but sometimes less is more. 😉
Kinbu
8 Oct 2024 09:58
GALEO4 schrieb:
These pieces of furniture from IKEA are generally designed more for short-term use
<br>That is mostly true, but there are definitely ways to significantly improve stability without having to buy new furniture altogether. For example, you can reinforce existing holes for connector bolts by applying wood glue and an appropriate wood filler, then re-tighten the screws. This reduces wobbling.<br>Also, precisely fitting back panels (thin chipboard) and additional corner brackets inside can make a big difference without needing to disassemble the furniture.<br>It is important to apply these improvements evenly; otherwise, the effect is limited.
likuken
8 Oct 2024 10:07
juMira46 schrieb:
My favorite tip: simply reinforce drawers and carcasses internally at stronger points with small brackets
<br>Always a nice and well-intentioned idea, but these “small brackets” come at a cost—not just financially. I think this only highlights that the furniture isn’t well-designed in terms of quality. <br>If you are truly thinking sustainably, there is little benefit in repeatedly applying quick fixes. There is a risk that the problem is ultimately only postponed, not solved.
flo-Theres
8 Oct 2024 10:15
A few practical tips: <br>- Regularly tighten the screws, as they tend to loosen quickly in particleboard furniture.<br>- Apply wood glue to the joints before tightening the screws; acting as an adhesive seal, this increases the mechanical stability.<br>- If the back panel is thin, it can be additionally supported with small battens, which stabilizes the entire chest of drawers.<br>These steps are simple and require minimal tools – usually a cordless screwdriver and wood glue are sufficient.
