ᐅ How can I reinforce Malm furniture to make it sturdier without using specialized tools?
Created on: 1 Jul 2021 08:47
Dilinda52D
Dilinda521 Jul 2021 08:47Hello everyone, I have some IKEA Malm furniture that I generally like, but unfortunately, some pieces seem a bit wobbly and unstable after some time of use. Since I don’t own any specialized tools and don’t want to buy any, I’m wondering: How can I make Malm furniture more stable without using special tools? Are there any tips or tricks to improve stability, perhaps by gluing afterward, reinforcing, or simple DIY solutions that work with common tools like a screwdriver, hammer, or similar? I would appreciate practical and easy-to-understand suggestions that can be done with limited resources.
Hello Dilinda52,
Regarding your question about how to make Malm furniture more stable without using special tools, there are several practical methods that work well. The first step is to identify the areas where the furniture feels wobbly – for example, loose screws or connections between the frame and drawers.
1. Tighten screws: Use a simple Phillips or flathead screwdriver, depending on the screws used. Often, the issue is just slightly loose fittings.
2. Use wood glue: If joints made of wooden strips or connectors are loose, applying wood glue can improve stability. You can apply the glue into the joints with a small spatula or an old piece of cardboard. Let it dry thoroughly, ideally with some weight on it.
3. Use washers: If screws slip in plastic anchors or turn loose, placing small washers under the screw heads can help make the connection firmer.
4. Attach felt pads or small brackets: If the cabinet wobbles on the floor, small furniture brackets – even simple metal brackets from a hardware store – can be installed underneath using a regular screwdriver.
I can only recommend this approach, as it doesn’t require special machines and often achieves the desired result. If you need more details on any of the steps, feel free to ask. 🙂
Dilinda52 schrieb:
Gibt es Tipps oder Tricks, mit denen man die Stabilität verbessern kann, vielleicht durch nachträgliches Verkleben, Verstärkungen oder einfache handwerkliche Lösungen[...]?
I would like to approach the topic of stabilizing IKEA Malm furniture in a more structured way, as there is often confusion around the term and many small tips that are hard to remember. Here is a clear guide with simple methods:
1. Check screws and dowels: A common beginner mistake is screws being too loose. Use a regular screwdriver to tighten all visible screws.
2. Use wood glue at contact points: Especially at solid wood joints (e.g., drawer fronts), carefully reinforce with wood glue. Apply a bit of glue into the joints and press with a clamp or improvised weight (e.g., heavy books). Wipe off excess glue immediately.
3. Attach support strips: If the cabinet’s stability mostly suffers from twisting, you can glue and screw simple wooden strips onto the back or inside (this can be done with regular screws and a screwdriver). This prevents unwanted movement.
4. Use washers for screws: As Takutau already mentioned, washers are great for widening the screw connection and achieving better load distribution.
5. Be cautious with excessive force: When tightening screws or adding reinforcements, be careful not to crack the particleboard panels. Work slowly and check regularly.
6. Check drawer slides: Overall stability often fluctuates due to play in the slides. These can be adjusted with a regular screwdriver.
I agree with this; it’s truly the simplest and least invasive method. If you need some additional tools for this, there are often inexpensive screwdriver sets for DIY work that are more than sufficient. Good luck!
Takutau schrieb:
Use wood glue: When joints made of wooden strips or connectors are loose, wood glue helps to improve stability.
bulanau schrieb:
Check the drawer slides: Overall stability often fluctuates due to play in the slides.Exactly. Tighten the drawer slides with a screwdriver.
Use washers with the screws.
Apply wood glue to the joints if screws alone do not provide enough stability.
