ᐅ How can I integrate doorbell or alarm systems into an Ikea Pax wardrobe?
Created on: 3 Dec 2023 08:17
tylerkin
tylerkin
3 Dec 2023 08:17
Hello everyone, I am currently planning to integrate a doorbell or alarm system into my newly installed Ikea Pax wardrobe to improve security and monitoring of its contents. The question is how to implement this technically in the best way without compromising the aesthetics due to visible cables or intrusive components. Are there specific sensors or alarm systems that can be easily integrated into the interior structure of a Pax wardrobe – perhaps hidden magnetic contacts that trigger an alarm when the wardrobe is opened? Also, how should I handle power supply if there is no direct access to an electrical outlet? I look forward to practical advice on which systems or components are recommended and the best ways to install something like this.
TRADI
3 Dec 2023 10:46
Hello tylerkin, that’s a very precise and interesting question. Regarding the integration of an alarm system into the Ikea Pax wardrobe, there are actually several approaches.
- Magnetic contacts are a proven solution because they are compact and discreet. You can attach them to the inside edge of the door so they are not visible when the door is closed.
- For power supply, battery-operated systems are recommended. There are many alarms that run on simple AA or AAA batteries and still work reliably.
- When installing, make sure to route the cables (if any) along the sides or back panels of the Pax. Cable channels or self-adhesive clips work well for this.
- If you prefer a smart solution, there are also wireless sensors that can connect via radio, for example, to a central unit on your smartphone.
The challenge is always to ensure the mounting is stable without damaging the furniture or affecting its appearance. Definitely measure carefully and test how the door opens and closes before installing. Hope this helps.
Keatondra
3 Dec 2023 15:29
TRADI schrieb:
Battery-powered systems are a good option for power supply. Many alarms operate reliably using simple AA or AAA batteries.
That's exactly the point: rechargeable, wireless sensors save a lot of effort when it comes to power supply. In addition, small wireless doorbell systems or alarms are easy to install.
- Simply attach the sensors at any desired locations — the strong adhesive strips ensure a secure hold.
- If you want, you can also use motion detectors. They react when a door is opened or when there is movement inside a cabinet.
- For an even more discreet installation, you can hide the sensors behind a cover plate or a small interior shelf.
Just make sure the sensor reliably triggers with movement or door opening and that the range to the control unit fits. That is often the biggest challenge with these systems.
Fitigu
4 Dec 2023 09:03
tylerkin schrieb:
Are there any special sensors or alarm systems that can be well integrated into the interior structure of a Pax—possibly with hidden magnetic contacts that trigger an alarm when the wardrobe is opened?
Integrating alarm systems into furniture like Ikea Pax can work technically well if certain criteria are met:
- Sensor type: Reed switches (magnetic contacts) are ideal because they are small, affordable, and reliable. They respond to the door opening by interrupting the magnetic field.
- Installation: The contacts can be discreetly mounted on the door frame and door panel, preferably using double-sided tape or screws if dismantling later is not a concern.
- Power supply: Battery-powered components are the most practical since running fixed wiring inside furniture is usually difficult. Pay attention to low battery consumption.
- System integration: Wireless systems with their own control panel allow flexible management and alerts via smartphone or audible alarms.
- Possibility of wiring: Cables can be routed invisibly inside the wardrobe sides or back panels. This is an advantage for wired systems.
For installation, I recommend temporarily attaching all components inside the wardrobe first and testing their function. Most wireless alarms support this procedure.
In conclusion: A component that does not compromise security or design should feature smaller sensor models and wireless control. Also, ensure compatibility with your preferred smart home system, if applicable.
