Hello everyone, I hope you can help me with a specific question about Ikea Hemnes furniture in rental apartments. I am planning to install some Hemnes furniture in my rental unit, but I am concerned because most of these pieces require wall mounting or drilling—which I want to avoid as much as possible to prevent any permanent damage to the property.
Specifically, I am interested in:
- What options exist for installing Hemnes furniture such as shelves, glass cabinets, or bed frames without creating drill holes or any other visible damage to the rental property?
- Are there any suitable alternatives or tricks you know of, for example, using special mounting systems, clamp fittings, or attachment with sealing tape?
- Are there any experiences regarding how durable these methods are, especially concerning the stability and safety of the furniture?
I would greatly appreciate practical advice or personal experiences. Thank you!
Rashadmeo7 Jul 2022 19:03Hey, great question! I also really love the Hemnes furniture – it’s sturdy and looks fantastic! 😍
Regarding your question: If you want to avoid drilling, I recommend using special clamp or tension brackets, which are available at most hardware stores. With these, you can secure shelves to the wall without screws. It’s important that the brackets are flexible but still hold the furniture firmly!
Alternatively, so-called “adhesive strip” systems that use strong adhesive tapes can be an option if your furniture isn’t too heavy. Just make sure to carefully read the manufacturer’s instructions so everything stays in place and no residue is left behind.
💡 My tip: First, test your chosen method on a small corner to see how stable it is – this way you can avoid bigger problems right from the start.
Don’t get discouraged; with a bit of creativity, you’ll do great! 🚀
Hello Ussau, I think your question is very well thought out, and I would like to bring some structure to the answer.
First of all, you should consider the type of load each piece of furniture will carry. A fully loaded Hemnes shelf requires a different mounting method than, for example, a dresser or a bed frame.
Here is a brief guide on how to proceed:
- For light to medium-weight furniture (e.g., small shelves): Use special adhesive pads or mounting tapes with high load capacity. Some flat-pack furniture even offers drill-free installation options, but you should consider the flexibility of the wall.
- For heavy, wall-mounted furniture (e.g., display cabinets): It is recommended to use load-bearing systems, such as so-called freestanding shelving units or furniture stabilized by weights on the floor.
- If the furniture is specifically designed for wall mounting (e.g., Hemnes wall shelves), tension rods between floor and ceiling might be a solution without leaving drill holes. These systems also provide sufficient stability in rental apartments.
- For bed frames, instead of drilling, you might use a frame that stabilizes itself through its own weight and proper positioning.
- Important: Place foam or felt pads under the furniture to protect the floor from damage.
In summary: The best method depends on the furniture type, weight, and your living space. Test beforehand and invest in sturdy mounting systems that can be removed cleanly.
If you like, I can recommend some specific products that I highly recommend!
Regarding assembling Hemnes furniture without drilling:
- Use corner brackets that can be attached inside the furniture.
- Use tension rods or straps between the ceiling and floor.
- Avoid placing heavy objects on the shelves.
These solutions are simple and protect the walls.
