ᐅ How can I customize and extend IKEA Metod kitchen cabinets?
Created on: 18 Aug 2022 19:37
LakilianHello everyone,
I am currently planning to customize and extend my IKEA Metod kitchen cabinets to better suit my specific needs. I am encountering some challenges and looking for tips on how to achieve this in the best way possible.
Specifically, I am interested in options for flexibly expanding the standard modules, for example by adding wall cabinets, custom interior drawers, special hardware, or combining them with cabinets from other series. I want to avoid compromising stability or functionality.
Other aspects include using custom-made shelves or additional interior organizers to make better use of the depth or create individual storage solutions.
Are there proven methods for attaching your own extensions? What are your experiences with modifications such as adding extra top or base moldings, installing LED lighting, or upgrading hinges?
I look forward to your experiences and helpful advice on how to customize Metod cabinets both functionally and aesthetically.
Lakilian schrieb:
Specifically, I am interested in options for flexibly expanding the standard modules, for example by using wall cabinets, custom interior drawers, special fittings, or combinations with cabinets from other series.I think it is important to critically consider to what extent combining with other series is actually practical. IKEA systems are often designed to be modular, but they are not always technically compatible. This can lead to instability or require complex adjustments to hinges and fasteners.
Regarding the use of wall cabinets: I would recommend checking the weight and load capacity of the base modules, even if the construction seems sturdy. Many underestimate the potential weakening of the joints when additional loads are applied.
I am also curious about your specific recommendations for the fittings. Are there alternatives to the original IKEA hardware that provide greater flexibility or durability?
Is anyone here familiar with custom interior drawers from third-party products or self-made solutions? I am interested in how well they fit into the Metod modules and whether there are noticeable compromises in functionality or durability.
sifope schrieb:
I’m also wondering what specific recommendations you have regarding the fittings? Are there alternatives to the original IKEA fittings that offer more flexibility or durability?Hello Lakilian and sifope,
From my experience, using high-quality fittings from furniture hardware suppliers can definitely offer advantages. Especially the stability of heavy drawers or fronts can often be improved. However, you should make sure that the dimensions and mounting points are compatible with the Metod cabinet measurements — this is crucial for a secure installation.
sifope schrieb:
Is anyone here familiar with custom interior drawers made from third-party products or DIY builds?Regarding interior drawers, I have had good results with custom-made wooden or metal drawers that fit perfectly with the Metod modules. It does require some craftsmanship, but the use of the full cabinet depth is greatly improved.
For stability with wall cabinets mounted on top, I recommend sufficiently reinforcing the connection points and possibly securing them with additional brackets to prevent wobbling.
Additionally, using LED strips under the upper cabinets not only provides pleasant lighting but also adds a modern touch, further enhancing individuality.
In summary, I would suggest:
- Use suitable fittings or focus on high-quality alternatives
- Customize interior drawers as needed or use made-to-measure modules
- Always securely fasten wall cabinets mounted on top
- Optionally complement with lighting
I hope this helps you further.
TEOZAR schrieb:
For stability with wall cabinets, I recommend reinforcing the connection points sufficiently and, if necessary, securing them with additional brackets to prevent wobbling.I can only agree with that. As a supplement, I would like to provide a brief step-by-step guide on how to customize and expand Metod cabinets individually:
- First, measure the existing cabinet dimensions precisely and check the load capacity, especially when stacking multiple units.
- Choose the type of extension: wall cabinet, pull-out drawer, or customized shelf compartments.
- For pull-out drawers, I recommend either the original IKEA VARIERA systems or alternatively custom-made boxes compatible with standard drawer slides.
- Inspect the mounting points and reinforce them if needed with special connectors such as metal rails or brackets.
- Adjust or add baseboards and cover panels to achieve a harmonious overall appearance.
- LED lighting or sensor lights can easily be mounted using clips or adhesive holders; pay attention to proper cable management.
- Interior organizers like cutlery trays, pot organizers, or special shelves usually comply with standard dimensions and significantly improve functionality.
A common mistake is overestimating the load-bearing capacity of the modules, especially for taller units or when loaded with heavy appliances. Proper alignment before final assembly is also important to avoid gaps or wobbling.
For those reasonably skilled with DIY, making custom shelves from suitable materials and thicknesses can further optimize storage space.
Conclusion: With careful planning and the right mounting hardware, the IKEA Metod system can be flexibly expanded and customized without any problems.
I have had good experiences with IKEA baseboards, which can be extended downwards, for example, in expansions. They fit precisely and are stable.
I also use modular interior drawers to make efficient use of depth.
For lighting, I rely on LED strips that can be easily attached underneath upper edges.
And basically: plan the weight of the cabinets carefully, otherwise there will be stability issues.
