ᐅ How can I improve the stability of IKEA Platsa shelving units?
Created on: 15 Jun 2021 08:37
Nonbla2Hello everyone,
I recently assembled an IKEA Platsa shelving unit to create some extra storage space. I noticed that the stability—especially with taller configurations or when storing many heavy items—does not always seem ideal.
My question is: How can I improve the stability of IKEA Platsa units without losing their modular advantages? Are there specific reinforcements, assembly tips, or other tricks to make the shelving safer and more stable?
I look forward to your experiences and advice!
To improve the stability of IKEA Platsa shelving units, I recommend the following measures:
- Always use the provided wall fixings and anchor them into the wall with appropriate anchors suited to the wall material.
- Avoid unevenly distributing heavy loads – store heavy items preferably at the bottom.
- If the shelving unit is tall, an additional cross brace can be installed at the back to reduce lateral wobbling.
- As another option, individual shelves can be reinforced further with brackets.
These steps work together to significantly enhance structural integrity and stability.
Hello Nonbla2,
I would like to give a detailed answer to your question about the stability of Platsa shelves, as the topic involves some nuances. The IKEA Platsa series is based on relatively thin particle boards with pine wood frames. This generally offers flexibility but also certain limitations regarding load capacity and stability.
A few detailed tips:
- Wall mounting: Essential for stability, I recommend using the included wall brackets and securing them into solid masonry with appropriately strong anchors. Drywall is more challenging; in this case, heavy-duty anchors or special metal fasteners are necessary.
- Module connection: If you assemble multiple modules, connect them using IKEA’s panel connectors or additional screws in the side panels. This makes the unit more rigid.
- Reinforcement: To avoid wobbling, you can add diagonal braces or a back panel made of thin plywood. In Platsa units, the back panel is often quite thin and mainly decorative.
- Weight distribution: Heavy items should be stored low and close to the wall. Avoid placing the load on just one shelf level to reduce the risk of tipping.
- Additional screws: Some users report that using self-tapping screws at critical connection points increases stability.
I would be interested to know how many modules you are using and whether your Platsa shelf is mounted on a wooden or concrete wall, as this significantly affects the best approach.
Domau0 schrieb:
I’m curious about how many modules you’re using and whether your Platsa shelf is mounted on a wooden or concrete wall? That significantly affects the best approach.Thanks in advance to everyone! Currently, I have two modules stacked on top of each other, so about 200 cm (79 inches) high. The wall is solid masonry (brick) with plaster. I used the supplied anchors, and the wall mounting is secured, but I still noticed slight flexing under load—especially when my partner accidentally shakes the shelf or when loading books.
I will definitely install an additional back panel, but I still need to get a suitable board for that.
What about cross braces—how exactly do you install them on Platsa without spoiling the look too much? Are there any special materials or tools recommended?
