ᐅ How can I improve the stability of IKEA Platsa shelving units?
Created on: 15 Jun 2021 08:37
Nonbla2
I recently assembled an IKEA Platsa shelving unit to create some extra storage space. I noticed that the stability—especially with taller configurations or when storing many heavy items—does not always seem ideal.
My question is: How can I improve the stability of IKEA Platsa units without losing their modular advantages? Are there specific reinforcements, assembly tips, or other tricks to make the shelving safer and more stable?
I look forward to your experiences and advice!
lorena
15 Jun 2021 16:47
Hello Nonbla2,
to answer your question more precisely: Cross braces can be installed as diagonal strips inside the modules. Ideally, use 12-15 mm (0.5-0.6 inch) thick plywood or wooden strips, fixed at a 45° angle between the side walls. You should secure these strips with small screws (e.g., 3x30 mm / 1/8x1 1/4 inch) to withstand shear forces.
Alternatively, thin flat steel strips can be used, which are screwed at the top and bottom of the frame – this provides a lot of additional strength with relatively little visual impact.
I recommend using a cordless drill with precision bits and a small protractor to check the exact angle while working. It is important that the braces are firmly seated to ensure the best possible stability.
Do you plan to stack more modules later? Because this will also affect the choice of reinforcements.
Nonbla2
16 Jun 2021 08:55
lorena schrieb:
Are you planning to stack more modules later? Because that also affects the choice of reinforcements.
At the moment, I don’t plan to add more modules; two stacked are more than enough since the shelving unit is in a corner and I don’t want to block any floor-level access.
The explanation about the diagonal braces sounds good, I will give that a try. One small question: Are the side panels of Platsa stable enough to screw into without splitting? Or are there special anchors or rails to attach the braces?
TARAON
16 Jun 2021 11:19
Hey Nonbla2,
great that you’re already thinking about the details! The Platsa shelving panels are made of medium-density particleboard with solid wood edges, which usually hold screws well if you pre-drill. I definitely recommend drilling pilot holes about 2-3 mm (0.08–0.12 inches) to prevent splitting.
When installing diagonal braces, you can also screw small metal or wooden angle brackets inside the corners if you don’t want visible screws—this looks like an installation detail but keeps things sturdy.
And just so you don’t worry too much: simply attaching the wall brackets with good anchors already reduces wobbling significantly. The extra reinforcements are basically the icing on the cake for very heavy loads or especially cautious minds.
Good luck putting it all together, and yes: a few extra screws make the shelf happy 😉
