ᐅ How can I modify IKEA PLATSA shelves to be more flexible?
Created on: 26 Oct 2021 19:27
Lopeo
Lopeo
26 Oct 2021 19:27
I recently purchased several IKEA Platsa units and want to modify them as flexibly as possible to fit different room layouts. I am particularly interested in ways to connect the modules to create a stable yet adaptable structure that can be expanded or rearranged when needed. Are there any tips for modifying the shelves so that restructuring can be done without heavy tools or full disassembly? What types of connections are practical and sturdy enough to allow such changes in everyday use? Additionally, I would appreciate recommendations on which combinations of shelf depths, heights, and widths work best for flexible adjustments. Best regards and thanks in advance for your advice!
flo-Theres
26 Oct 2021 20:13
Lopeo schrieb:
Are there any tips for modifying the shelves so that rearranging them is possible without using many tools or dismantling?
In general, the IKEA PLATSA shelves are quite modular and easy to assemble. For flexible reconfiguration, I would recommend securing the individual modules only with the original connectors, those clip connections that can be released without a screwdriver. This way, you can easily detach and rearrange individual units at any time.
Regarding stability, it’s advisable to place larger modules at the bottom and smaller ones on top. I would not recommend directly connecting modules with different depths, as this can lead to instability. Instead, position them side by side and, if the setup is meant to be permanent, consider reinforcing with sturdy brackets.
As for width options, the 60 cm (24 inches) modules are the most common and offer the best balance of flexibility and storage space. For special corners or narrow spaces, the 40 cm (16 inches) or 80 cm (31 inches) widths can also be useful, depending on the layout of the room.
Jatau
27 Oct 2021 07:49
flo-Theres schrieb:
For flexible redesign, I would recommend securing the individual modules only with the original connecting elements
I can confirm that. Secure the modules only with the plug-in connectors, so you can separate and modify them at any time. You generally don’t need any tools for rearranging.
MUMENAR
27 Oct 2021 09:22
Lopeo schrieb:
Which types of connections are practical and durable enough to keep such a conversion usable in everyday life?
It is important to critically assess how stable the entire structure can really be when prioritizing maximum flexibility. Plug-in connections clearly allow quick conversion, but especially for heavier-loaded shelves or larger constructions, these connections may become weak over time.
Another point to consider: if you sometimes want to change the depth or height, it is worth thinking about modular additions with separate back panels. The back panel provides significant stability while allowing greater variability.
I would also suggest considering that a certain compromise between flexibility and stability is usually necessary, and depending on the intended use, permanent fixing in some areas may be advisable.
Elodie
27 Oct 2021 12:31
MUMENAR schrieb:
One more thing: If you sometimes want to change the depth or height, it’s worth considering modular additions with separate back panels.
You’re absolutely right! I built my PLATSA so that I can easily remove individual modules, but the back panels stay attached. That provides great stability—almost like a puzzle that fits perfectly together. And don’t worry, reconfiguring it is actually fun!
I also recommend getting a few extra feet or adjustable leveling legs from IKEA. They gave my setup the final touch of stability, especially on slightly uneven floors. This way, nothing wobbles, and the flexible concept stays intact. It also helps avoid an “IKEA screwdriver disaster” while still allowing for lots of experimentation.
flo-Theres
28 Oct 2021 08:04
Lopeo schrieb:
I am also interested in any recommendations on which combinations of shelf depths, heights, and widths work best for flexible adjustments.
My recommendation is to go with the common height of 192 cm (75.6 inches), as it allows you to use many adjustable shelves flexibly. Larger modules are often difficult to move and modify.
I would keep the depth at the standard 35 cm (14 inches), because while deeper modules offer more storage space, they are also bulkier. This way, you can rearrange the shelves more easily, especially if the connections are only slotted.
For the width, I prefer the 60 cm (24 inches) modules, as they stack well and can be expanded, particularly when combined with smaller modules to fill in remaining spaces.
