Hello everyone, I own several IKEA Malm furniture pieces that I actually like in terms of design, but I would like to enhance their color to make them more individual and modern. I am thinking about paint, lacquer, or maybe some decorations. My specific question is: How can I update the color of Malm furniture, which materials and techniques work well, and what should I keep in mind to ensure the result looks good long-term while keeping the furniture functional? I look forward to tips, experiences, or creative ideas!
Hello, I think your question is very well phrased because it specifically addresses the method and sustainability. Basically, Malm furniture is made of coated particleboard, which means you should make sure to sand the surface well before applying paint so that it adheres properly. I then recommend using a suitable primer, as the paint might otherwise peel off easily. For the choice of paint, I would suggest water-based acrylic paints because they are durable and low in odor. After painting, a clear coat can provide additional protection, but this is optional. Where do you plan to use the furniture – in the bedroom, office, or another room? That could influence the choice of color.
I find refurbishing furniture really fascinating, especially because it adds a touch of personality to the home. I’ve tried it myself and can say it’s a lot of fun, but it requires patience and good materials. It was also important to me that the surface not only looks good but can withstand scratches and moisture. That’s why I chose a harder sealant. However, I’ve noticed it can sometimes be frustrating when touch-ups are needed – especially with Malm furniture, since the material doesn’t absorb paint as well as solid wood. Maybe you’d like to share how it’s going for you!
Thank you for the initial tips and assessments! I’m planning to change the colors of the furniture in the bedroom and living room. So far, the furniture has a white coated surface, and I would like to try something elegant like pastel tones or matte colors, possibly with some accents in darker shades. It seems that sanding and priming are really necessary, even though I don’t want to damage the surface too much because I’d like to keep the smooth finish typical of IKEA furniture. Has anyone had experience with whether spray paint or brush application works better? Also, what about chipping or adhesion issues if the paint is just applied on top?
This is an important question. Spray paint can create a very smooth and even finish, especially on smooth surfaces like Malm furniture. However, it is crucial to slightly roughen the surface beforehand, for example with sandpaper grit 220 to 320, so that the primer and paint adhere properly. When using a brush, it is best to choose high-quality, flat brushes to avoid streaks. If you work carefully and apply several thin layers of paint, the risk of peeling is low. It is also advisable to consider room temperature and humidity levels during the painting process, as these factors affect drying time.
