ᐅ How can I customize the color of IKEA HEMNES furniture?
Created on: 14 Nov 2020 08:43
Benjon
Hello everyone, I want to customize the color of my IKEA Hemnes furniture and am looking for effective and proven methods to achieve the best possible result. Specifically, I am interested in ways to treat and protect the surface so that the furniture not only looks good but also remains durable. Which types of paints or varnishes are best suited for frequently used pine wood? Are there any necessary preparatory steps like sanding or special primers that should be considered? I would also appreciate tips on how to avoid common mistakes, for example when applying the paint or regarding drying times. I look forward to your experiences and suggestions!
Sinan-meo
15 Nov 2020 18:15
The matte-satin finish is a good balance between design and functionality, especially for frequently used furniture like yours. For this project, I recommend the following steps: - After thorough sanding, apply a white or clear two-component (2K) primer suitable for pine wood. This ensures good adhesion and prevents discoloration. - Use a high-quality acrylic paint certified for furniture as the color layer, with color selection according to your preference. - Apply a clear coat with a matte or satin finish specifically designed for furniture, which is durable and resistant to scratches and dirt. It is important to follow the manufacturer’s instructions regarding drying times and application to achieve the best results. Modern products often become touch-dry within 1 to 2 hours and fully cured after 12 to 24 hours. You should plan for about 2 to 3 days for the entire process if you carefully observe the drying phases and work in a well-ventilated area.
roryvin
16 Nov 2020 07:43
Hello Benjon, as a supplement to the previous posts, I can point out the following: When sanding, be careful not to roughen the surface too much to avoid damaging the wood fibers. Use fine sandpaper (220 grit) for intermediate sanding to remove unevenness. When choosing paint: water-based acrylic enamels are considered particularly durable and environmentally friendly. If you are looking for a specific paint that is especially lightfast and abrasion-resistant, pay attention to the manufacturer’s information. For protection, I recommend clear coats with a hardener component (2K coatings), as these are more durable than 1K variants. Finally, remember to ventilate your workspace and avoid dust during drying to ensure a smooth surface.
bupar
16 Nov 2020 13:06
That is correct, and therefore I would recommend only performing intermediate sanding if the manufacturer explicitly advises it. Many modern 2K and 1K systems do not require intermediate sanding, which reduces the amount of work. Additionally, choosing a good primer and high-quality paint is crucial for durability. It is also advisable to always test the paint on an inconspicuous spot to check color tone and adhesion. For frequently used furniture, a combination of primer, paint coat, and a topcoat with good abrasion resistance is recommended. The combination of acrylic paint and PU clear coat has proven to be very effective.
LENNAU
17 Nov 2020 10:11
Benjon schrieb:
The furniture will mainly be placed in the living room and will be used quite frequently in daily life, such as cabinets and dressers that are accessed often.
For frequent use, I recommend paying special attention to sanding the edges and corners thoroughly, as these areas tend to experience more wear. It’s also worth considering clear varnishes that comply with DIN standards or other quality indicators like abrasion resistance. If you have a bit more time, I would suggest lightly going over the surface with a polishing pad or abrasive fleece on at least two evenings—once after sanding and once after applying the paint. This will help you achieve a very high-quality finish. If you’re pressed for time, use high-quality products and ensure good room temperature and ventilation, which significantly improve the drying process.
