ᐅ How can I customize the color of IKEA HEMNES furniture?
Created on: 14 Nov 2020 08:43
Benjon
Benjon
14 Nov 2020 08:43
Hello everyone, I want to customize the color of my IKEA Hemnes furniture and am looking for effective and proven methods to achieve the best possible result. Specifically, I am interested in ways to treat and protect the surface so that the furniture not only looks good but also remains durable. Which types of paints or varnishes are best suited for frequently used pine wood? Are there any necessary preparatory steps like sanding or special primers that should be considered? I would also appreciate tips on how to avoid common mistakes, for example when applying the paint or regarding drying times. I look forward to your experiences and suggestions!
LENNAU
14 Nov 2020 09:27
Hello Benjon, your question is very well thought out, and especially with HEMNES furniture made of pine wood, it’s a great idea to change the color. In general, it is important to sand the furniture thoroughly beforehand to roughen up the existing lacquer or surface and ensure better adhesion of the new paint. You can use fine sandpaper (grit 120 to 180) and be careful not to round off the edges too much. For the paint choice, acrylic paints or special water-based furniture paints work well, as they have low odor and are more environmentally friendly. If you want a particularly durable surface, I would recommend applying a protective clear coat after painting, preferably matte or satin finish, depending on your preference. A primer, especially a wood primer, can help make the paint more durable and achieve a more even finish. It is also important to follow the drying times carefully and ventilate the rooms well in between. If the furniture will be heavily used, several thin layers of paint are better than one thick layer. If you have any questions about this, I’m happy to help!
GUSTAVO56
14 Nov 2020 11:52
Hello Benjon, I will address your question in detail: HEMNES furniture is made from pine wood, which is generally a relatively soft type of wood. Therefore, you should prepare the surface properly to achieve a good result. 1. First, remove all handles and fittings to work evenly. 2. Sanding: Use sandpaper with a grit of 150 and work preferably in the direction of the wood grain. This way, you remove signs of aging and make the surface ready to absorb paint. 3. Then, remove the dust with a damp cloth or a tack cloth. 4. Primer: I recommend a sealing primer specifically designed for resin-rich woods like pine. It prevents resin from bleeding through and ensures a uniform base. 5. Paint: For furniture, I recommend either water-based acrylic paints, which have low odor and dry quickly, or two-component (2K) paints if you want a particularly durable surface. 6. Paint application: Apply several thin layers of paint, allowing each to dry thoroughly (at least 6 hours, ideally 12). Sanding between coats with 240-320 grit ensures durability and smoothness. 7. Clear coat: A matt or satin clear coat protects against scratches and moisture. If the furniture is used frequently, a polyurethane (PU) clear coat is advisable. 8. Sanding at every intermediate step is tedious but worthwhile. My questions for you: How heavily used are the furniture pieces? Where will they be placed? Do you prefer a matt or glossy finish? Depending on your answers, I can provide more specific advice. I hope this list helps you get started.
TRA33
14 Nov 2020 12:20
The best way to paint HEMNES furniture is as follows: sand the furniture thoroughly, apply a primer, paint with acrylic paint, and finally apply a clear lacquer. Allow each layer to dry completely.
NUGRANT
15 Nov 2020 16:34
Wow, this is a really exciting discussion! I painted my HEMNES dresser last year with chalk paint – it was a lot of fun and the result turned out great! The nice thing about chalk paints is that they’re very easy to work with, even for beginners. For the finish, I applied some wax to make the surface less sensitive. I’m really impressed! So if you want a custom, matte finish, definitely give it a try. And don’t be afraid of sanding – that’s truly the key to success. Good luck, and let us know how it goes!
Benjon
15 Nov 2020 17:05
GUSTAVO56 schrieb:
How heavily will the furniture be used? Where will it be placed? Do you prefer a matte or glossy finish?
Thank you for the detailed response! The furniture will mainly be in the living room and will be used quite frequently in daily life—so cabinets and dressers that will often be accessed. The surface should therefore be durable; I’m leaning towards a matte-satin finish because I like a slight sheen but not high gloss. Do you have recommendations for specific brands or products that have proven reliable? Also, how long does the entire process usually take? I can’t afford to wait too long.
