ᐅ How can I customize IKEA Platsa furniture for an office?
Created on: 25 Jan 2018 08:42
boraneo
boraneo
25 Jan 2018 08:42
Hello everyone, I’m considering how to customize the IKEA Platsa furniture specifically for an office. I want the result to be not only functional but also visually appealing, to enhance both the working atmosphere and practical use. What options are there for modifying the modules, such as changing colors, adding extra components like drawers or lighting? Are there any tips for DIY modifications that don’t require extensive DIY skills? What experiences do you have with adapting Platsa to specific office needs, for example cable management or ergonomic shelving? I look forward to your diverse suggestions and experiences!
Tommy38
25 Jan 2018 09:17
Hello boraneo, your concern is interesting and can be addressed in various ways. Platsa is basically very modular, which allows you to easily adapt it to different office requirements. You can customize the color with paint or adhesive films, both of which are relatively simple and cost-effective. For additional storage space, you can add extra drawers or use adjustable shelves. For lighting, you could install LED strips inside to better illuminate the workspace. For cable management, there are clips or cable ducts that can be attached either inside or outside the furniture. It is important to measure precisely beforehand to ensure everything fits. If you are looking for a more ergonomic solution for trays or surfaces, consider height-adjustable shelves or external accessories. Hope this helps you so far!
Rosan
25 Jan 2018 11:03
Platsa can be easily covered with colored films if you want to change the colors. Additionally, IKEA drawers offer a simple, clean solution for better organization. LED strips can be installed inside – this creates ambiance and more practical lighting. Cable clips on the sides help with cable management.
Jamalli
25 Jan 2018 14:28
Tommy38 schrieb:
You can enhance the lighting, for example, with LED strips installed inside to better illuminate the workspace.
That’s a good idea, but it’s important to consider the effect of the LED light. Some LEDs are very cool in tone and can negatively impact the working atmosphere. Warm white LEDs or dimmable options are better, as they allow more flexible lighting.
These films are practical but sometimes have a limited lifespan in terms of quality. If you want a more durable and high-quality look over time, painting or even professional wrapping would be a better option. It’s also worth considering how such films hold up under heavy use in an office—frequently used surfaces might wear out more quickly.
Additionally, it’s rare to find suitable ergonomic solutions for Platsa directly from IKEA. It’s advisable to look into third-party accessories or custom modifications, such as tailored shelves or additional adjustments to the furniture itself.
boraneo
26 Jan 2018 07:56
Jamalli schrieb:
That’s a good idea, but you should also consider the effect of the LED lighting.
Thank you for the valuable tip regarding lighting. I was unsure how it would impact the working atmosphere. Warm white seems like a reasonable compromise.
Tommy38 schrieb:
If you’re looking for a more ergonomic solution for storage, you might consider height-adjustable shelves or external accessories.
Could you possibly recommend specific products or solutions for this? For example, how to easily retrofit them or attach them to the Platsa system?
Also, I’m struggling a bit with the material when it comes to painting. Who has experience with suitable paints or techniques that don’t damage the Platsa surface while remaining durable?
TEKIN
26 Jan 2018 10:22
For customizing Platsa furniture for the office, the following practical approaches are recommended:
- Color design: Use acrylic or alkyd-based paints suitable for laminate and particleboard surfaces. Thorough surface preparation by sanding improves adhesion. Applying a primer is strongly advised.
- Lighting: Warm white LED strips with dimming capabilities are minimally invasive and enhance the working atmosphere. Installing them inside the modules is easily achievable.
- Accessories: Height-adjustable shelves can be mounted using adapter brackets or clips that attach specifically to the Platsa doors or interior sides. Drawer units from the IKEA range or third-party suppliers are also compatible.
- Cable management: Special cable channels or self-adhesive holders from electrical supply stores help keep cables organized and reduce tripping hazards.
- Stability and ergonomics: To optimize working height, Platsa units can be mounted on height-adjustable table frames or standardized furniture legs.
These points have been extensively tested in practice and provide a solid foundation for customized office setups using the Platsa system.
