ᐅ How can I cheaply replace lost PAX assembly screws?
Created on: 22 Oct 2021 20:07
fulapra
Hello everyone, I unfortunately lost some assembly screws for my Ikea PAX wardrobe that are necessary to secure the side panels and shelves. I am now looking for an affordable and as simple as possible way to replace these screws without having to buy new complete PAX sets. Does anyone have experience with purchasing the original screws again, or are there comparable alternatives that can be obtained cheaply at a hardware store or online? It is important to me that the screws are not only inexpensive but also sturdy and the right length and thread size. I would appreciate any tips on where and how to get such replacement screws affordably and what to look out for.
gekira
23 Oct 2021 09:35
For factual clarification: The Pax assembly screws are standard metric wood screws with typical thread spacing. For replacements, screws with a diameter of 4 mm (0.16 inches) and a length of 30 to 40 mm (1.2 to 1.6 inches) are recommended, depending on the application.
You can find suitable screws under the designation "flat head wood screws" or "furniture screws" in the standard range of most hardware stores. It is important that they are made of galvanized steel to prevent corrosion.
Ikea offers replacement parts for many products through customer service at relatively reasonable prices. It is advisable to specifically inquire about available screw or replacement kits, as availability varies.
In general, a practical alternative is to purchase screw sets that include multiple common sizes, also for furniture assembly. These sets are usually cost-effective and can be useful in the long term if additional screws get lost.
Jensson
23 Oct 2021 12:54
Here is a simple step-by-step guide for replacing missing PAX screws:
- Step 1: Measure the screws (length, diameter, thread type).
- Step 2: Check how many screws are needed and which mounting points they belong to.
- Step 3: Look specifically for these furniture wood screws at your local hardware store. Ask for "4x35 mm flat head screws" as this size usually fits.
- Step 4: Test one screw first. If it fits perfectly, proceed with the rest.
Make sure to use screws with a flat head so they sit flush with the wood surface and don’t cause any unevenness. Common material is zinc-plated steel for durability.
This way, you avoid expensive original spare parts while still using stable and suitable screws.
puvin
23 Oct 2021 17:29
Hey, this sounds like a classic case of "small problem, big impact"! It’s great that you’re tackling it because buying individual screws instead of whole sets is usually much cheaper and more environmentally friendly.
Here’s a little extra tip: If you stock up on a small selection of wood screws in various sizes, you’ll always have a quick solution ready for situations like this. It saves stress and makes you feel a bit more handy!
Keep at it and don’t worry, you’ll definitely manage this easily. Have fun with the screwing!
