ᐅ How can I assemble Ikea Metod cabinets so that they are quiet?
Created on: 22 Nov 2021 18:47
AnrelaHello everyone,
I am planning to assemble several IKEA Metod kitchen cabinets soon, but from previous projects, I have often noticed that the cabinets can be quite noisy when closing or even during the assembly process itself. My question is: How can I specifically approach assembling the IKEA Metod cabinets to keep noise to a minimum?
I am concerned both about the sounds during assembly (creaking wooden parts, squeaking screws, etc.) and about keeping the cabinets quiet in everyday use, for example when opening or closing the doors. I have already tried using felt pads in some areas, but I am missing a systematic approach or the best practices—perhaps also suitable tools or tricks I should consider.
I would appreciate it if you could share your experiences, preferably with technical details that help with the modular construction of the Metod series. Thanks in advance!
Anrela schrieb:
How can I specifically approach assembling IKEA Metod cabinets to make the process as quiet as possible?That’s a very good question, as noise during assembly and especially in daily use is often underestimated.
Basically, there are several ways to minimize noise with Metod cabinets:
- Clean the connection points before assembly: IKEA provides pre-drilled holes for dowels and screws, but dust or wood shavings can later cause creaking. Before assembly, I recommend blowing out all holes with a brush and, if necessary, using fine sandpaper on the edges.
- Use a small amount of wet wood glue on the dowel points: This creates a more stable joint without movement that can cause creaking. Be careful, though, as too much glue may make future disassembly more difficult.
- Screw carefully without applying excessive force: Over-tightening screws can deform the material and cause noise. Precise tightening ensures a firm fit without tension.
- Attach thin felt or foam pads at contact points, for example behind door hinges and between cabinet sides where they meet. This dampens rubbing sounds.
- Check the hinges: If the factory settings are not properly adjusted, they can squeak when closing. Occasionally a small amount of specialized oil or silicone spray helps – but use sparingly and carefully.
- Finally: the Metod series is coated with melamine. The edges should be deburred before assembly to avoid localized friction noises.
Could you specify if you’re more concerned about noise during assembly or the noise in everyday use? Completely silent assembly is almost impossible, but many tips can significantly reduce noise.
Palenar schrieb:
Could you specify whether you are more concerned about noise during construction or everyday noise afterward?From my perspective, Palenar’s points are very comprehensive. In addition, I would like to summarize in a structured way how to build Metod cabinets to minimize noise, referring to both phases – assembly and long-term use:
- Preparation:
- Use tools such as a cordless screwdriver with torque control to insert screws carefully.
- Use a work surface with soft padding (foam rubber, felt) to place the components on.
- Assembly:
- Clean all connection points before assembly, as described.
- Avoid cracking noises by inserting dowels precisely, possibly with slight sanding of edges.
- Do not overtighten screws; observe torque limits, as Palenar mentioned.
- Post-assembly:
- Check magnets and dampers on the inside of doors.
- Consider using noise-dampening seals on the frame.
- Apply lubricant at door hinges if needed, but be mindful of areas near food storage.
Important: The melamine coating is durable but fairly rigid, which transmits minor vibrations. Therefore, mounting soft damping materials in the right places helps significantly.
This way, the cabinet furniture can be made noticeably quieter.
Anrela schrieb:
I’m concerned both about the noises during assembly (creaking wood parts, squeaking screws, etc.) and about keeping the cabinets quiet in everyday use, for example when opening or closing the doors.Sounds like you have quite a big project underway! 🙂 I once assembled a Metod kitchen, and it was far from quiet—every screw seemed to have its own soundtrack.
My tip for assembly is: make yourself comfortable and take your time. Have you tried applying a bit of wax to the screw tips before driving them in? That speeds up the screwing process and prevents creaking.
For quieter door closing afterward, I gave mine a little extra attention: I attached felt pads not only on the feet but also inside the doors. Where wood otherwise rubs against wood and squeaks, this really makes a difference.
Also, you can adjust a bit of damping with the included bumpers—I like replacing the standard ones in squeaky spots with higher-quality rubber bumpers.
I’d say a quiet assembly is already half the battle—and if you cleverly distribute some of these small rubber bumpers, even a Metod kitchen can become really quiet. Good luck!
Roberta schrieb:
Simply spray all movable parts lightly with some silicone spray before installation.That’s a sensible classic tip, but I would like to add: silicone spray should be used sparingly and only in specific spots, as excessive application attracts dust and can create sticky residues over time, which is counterproductive.
Katan schrieb:
Make yourself comfortable and take your time – have you ever tried applying a bit of wax to the tip of the screws before installing them?I also find the wax trick very effective, especially if you don’t have a cordless drill with torque control. You should use pure beeswax or special assembly wax for this. It significantly reduces friction, which noticeably minimizes the repetitive creaking noises of the fasteners during screwing.
Finally, a question for Anrela: Are there particular types or sizes of cabinets where this problem occurs more often? Sometimes large, heavy cabinets with many doors or drawers present different challenges than smaller base cabinets.
