ᐅ Floor plan design for a single-family house, 165 sqm, without a basement, on a 400 sqm plot
Created on: 10 Aug 2023 09:33
Maulwurfbau
At the request of 11ant, here is a post with the completed list ;-) Unfortunately, he still doesn’t have a crystal ball.
Providing all information possible/available at this point in time.
Plot size: 400 sqm (4300 sq ft)
Slope: No, and no means no!
Floor space index (FSI): 0.4
Floor area ratio (FAR): ?
Building envelope, building line and boundary: Yes, available.
Edge development: Possible with garage.
Number of parking spaces: at least 1, preferably 2
Number of storeys: 1-2
Roof type: Gable roof (pitch minimum 31°, maximum 45°)
Architectural style: ??
Orientation: Gable end facing
Maximum heights / limits: Roof ridge 6-7 m (20-23 ft), eaves 9-12 m (30-39 ft)
Other requirements: No brick facades allowed. Driveway or space in front of garage at least 6 m (20 ft). Red roof tiles mandatory, light facade.
Homeowners’ Requirements
Architectural style, roof type, building type: Gable roof, fixed
Basement, storeys: 2 full storeys without basement
Number of occupants, age: 4 people (2 toddlers)
Space requirements on ground floor and upper floor:
Office: Family use or home office? Office of approx. 12 sqm (130 sq ft) is a must.
Guest bedrooms per year: Few
Open or closed architecture: ? Whatever that means.
Conservative or modern construction style: rather modern construction.
Open kitchen, cooking island: Open kitchen, possibly with cooking island
Number of dining seats: 6
Fireplace: NO
Music / stereo wall: Not planned, TV location is quite important.
Balcony, roof terrace: NO
Garage, carport: Garage desired. Carport with storage box also conceivable.
Utility garden, greenhouse: NO
Further wishes / special features / daily routine, preferably with reasons for choices:
Laundry room on the upper floor. They want to do laundry where it is generated and where it must be returned clean. Anything else is a hassle, at least for us.
Who designed the plan: Architect
Everything we provided as basic information and what our daily life requires has been implemented.
We like the clear lines/structure.
The open space in the hallway.
The connection/proximity of all rooms on ground and upper floors that need water/sewage. So no funny business with the bathroom upstairs in one corner and the utility room diagonally opposite on the ground floor. Personally, I like that.
No bay windows or other awkward extensions.
Laundry room upstairs where the washer and dryer are planned.
What don’t you like? Why?
The living room might be a bit too exposed for us. It could also be a cozy nook with TV without direct view of the kitchen. Cooking and eating together openly is liked; the living room could be a bit more separate. Currently, the floor plan shows it like a narrow, rather shadowy corner.
The somewhat narrow bedroom upstairs is not a dealbreaker but not 100% pleasing.
Personal price limit for the house, including fixtures and fittings:
500-575k
Preferred heating system:
Predefined, ground source heat pump with collector. Cold local heating network.
If you have to give up, which details/extras
-can you do without:
The small additional room for the father upstairs.
Garage, as mentioned carport also conceivable.
-can you not do without:
Office.
Storage box at garage or carport.
Children’s rooms.
The design turned out this way because the architect implemented our wishes and requirements almost 1:1. This preliminary layout resulted in this first version.
What do you consider particularly good or bad?
See what we like and what not. We don’t find anything particularly bad. Rather, not entirely optimal.
Position garage flush with house or set back?
43.5 sqm (468 sq ft) + 4 sqm (43 sq ft) pantry sufficient as “all-purpose room”?
Same floor plan possibly mirrored? Then office on south side, sun all day, blinds always down. Same issue upstairs with bedroom in summer at least. Entrance farther from parking space.
The building method will be timber frame construction with a local timber builder.
This is a first sketch after clarifying needs/wishes with the architect.
Fireplace: NO
500-575k
Office.
Children’s rooms.
Maulwurfbau schrieb:
Here you go. Slightly revised. We are now very satisfied with it. Are there also elevations available? The windows still seem a bit unbalanced to me, don’t they?
Maulwurfbau14 Mar 2024 20:23Gerddieter schrieb:
I also had such a useless wall installed in the bedroom. I regret it now. It’s load-bearing, and if I wanted to remove it, I would have to deal with all the structural engineering again...
Your wall just makes the room feel cramped and what is it supposed to achieve? Leave it as it is, and if anything, build it with drywall – then it can be removed quickly...
GD Yeah. I understand your point.
We wanted it that way. So, removing it in the future would only be in extreme cases, but it probably won’t be necessary.
Maulwurfbau14 Mar 2024 20:25K a t j a schrieb:
Are there any renderings available? The windows still seem a bit unbalanced to me, don’t they? I only have it as a PDF at the moment. But I understand what you mean. It just looks different from about 90% of single-family houses in a typical German single-family home neighborhood. That might confuse some people. But yes, I know what you mean.
hanghaus202314 Mar 2024 21:39Then go ahead and send it, PDF is fine.
The walk-in closet is not really a walk-in closet. Therefore, the objection is justified.
Maulwurfbau14 Mar 2024 21:43It is not a walk-in closet, as nobody dresses there. It is a "wardrobe" corner that is somewhat hidden behind a wall. That’s all.
No, I won’t make a PDF. All names, addresses, and phone numbers are included in the drawings. I need to take screenshots of the relevant sections on the interested parties’ computers.
hanghaus202314 Mar 2024 22:05If you place a room divider with a TV there instead of a wall, you will be more flexible.
You should also reconsider the large windows. They will become quite expensive.
