ᐅ Ground Floor Layout Planning for a 150 sqm Urban Villa
Created on: 17 May 2020 10:41
morgenstern
I have been following the discussions for a long time, and now it’s finally getting serious:
Lot size: 621 sqm (6690 sq ft)
Slope: No
Floor area ratio: 0.35
Building window, building line, and boundary: see attachment
Setback from boundary: 3 m (10 feet)
Number of floors: 2
Maximum heights / limits: Ridge height 6.5 m (21 feet) / Eaves height 10.5 m (34 feet)
Homeowners’ Requirements
Style, roof type, building type: Hip roof, “city villa”
Basement, floors: 2 full floors plus basement
Number of occupants, ages: 3 (40, 34, 2)
Space requirements on ground floor (GF) and upper floor (UF):
GF: Kitchen (with pantry), dining/living, office (convertible to bedroom later), guest bathroom with shower, cloakroom
Office use: Home office 3 days per week
Guest sleepers per year: 2
Open or closed layout: rather closed
Conservative or modern construction: feels modern
Open kitchen, cooking island: L-shaped kitchen
Number of dining seats: 4 normally, expandable to 8
Fireplace: yes (but could be dropped)
Music/stereo wall: no
Who designed the plan:
- Designer from a construction company
What do we particularly like?
All requirements are covered:
Living area should be at least approximately 3.8 m x 3.8 m (12.5 ft x 12.5 ft) so that existing furniture fits and we feel comfortable.
The dining area should be connected but not a narrow corridor. The first plan had living/dining combined in a 9 m x 3.5 m (30 ft x 11.5 ft) space, which we have seen at friends’ houses, but it doesn’t feel comfortable or easily furnished to us.
We tried to optimize some square meters to reduce the cost.
The office should, in later years, be able to hold a 3 m (10 ft) wardrobe and a double bed.
What do we not like? Why?
The fireplace would be nice but might make the passage between dining and living too narrow, which could be risky with a child when the fireplace is in use. The pantry could be a bit small.
Cost estimate according to general contractor:
470,000 including basement (one room finished), controlled mechanical ventilation, air-source heat pump (eligible for subsidies), laundry chute, KfW 55 standard without deduction of subsidies, without garage.
Personal price limit for the house including fittings: basically already reached with this.
Preferred heating technology:
Air-source heat pump
If you had to give up something, what details or extras could you do without?
- Can give up:
Basement finishing, fireplace
- Cannot give up:
Controlled ventilation, laundry chute, smaller size not possible
Why is the design the way it is now? For example:
This is the third iteration in which all requirements are met for the first time.
Where could optimization still be possible? For example, the passage around the fireplace?
Is the dining room wide enough to pass by comfortably?
Would a different staircase shape help?
We generally like the floor plan very much but are a bit frustrated because it’s not really spacious for the budget.
There is a concern that it might end up too small.
The upper floor is slightly smaller, rectangular. The "bay window" at the living room is removed.
A few words about the location / development plan / building window:
Access to the garage would be through the small section in the southeast. This is a residential street.
To our north, a slightly larger road is planned, but it will only serve traffic to the new developments.
North of that road is open field and likely will remain so for the next 15 years.
We are at the northwest edge of the building area; a nature reserve (forest) starts to the west.
The north arrow in the (redrawn) plan is incorrect. The plan should be rotated ca. 10–15° clockwise.
At the northwest corner, we already touch the building window, as well as on the eastern side with the garage.
Floor plan: living room, dining, office, kitchen, hallway, guest WC, cloakroom, pantry, garage.
Map excerpt: pink area with cyan lines, water surface above, fence points, right star marker
Maria16
17 May 2020 22:25
Why do you want to be on the ground floor in old age? Is it to accommodate a wheelchair? If so, there must be enough space, especially in the bathroom and around the bed.
Should the upper floor then be vacated when you move to the office?
I would seriously reconsider having the double bed on the ground floor.
Curly
17 May 2020 23:09
There are also stairlifts available.
Sabine
11ant18 May 2020 02:28
Alessandro
18 May 2020 12:57
I wouldn't find the hallway without lighting too problematic if you also plan for a fixed window next to the front door.
morgenstern
18 May 2020 21:33
The fixed glazing probably wouldn’t help either, since the garage roof extends over the front door. That would likely make the area quite dark.
I think we’ll just have to start over with a blank sheet of paper.
We were satisfied with the floor plan because all of our requirements were met.
You showed us that this came at the expense of several other things, which is not acceptable.
18 May 2020 23:32
morgenstern schrieb:
because the budget is not really generous.
Many rooms have awkward shapes.
The floor plan reminded me of a house that has been remodeled three times.
Bathroom awkwardly shaped, office awkwardly shaped, kitchen awkwardly shaped. Hallway quite narrow and dark.
There is hardly any space to move or develop.
The office is supposed to accommodate a 3m (10 feet) wardrobe and a double bed in old age.
The entire ground floor is not suitable for aging, unless you plan to hold onto the walls instead of using a walker.
Could it be that one of your requirements is “not as boring as other floor plans”?
Please keep in mind: standard works, and rectangular rooms have enough space to furnish.
