ᐅ Built-in Refrigerator Installation in a Fitted Kitchen – Any Tips?
Created on: 24 Jun 2018 11:28
ashleyHello, we have an old built-in refrigerator in the kitchen. Now we want to remove the refrigerator along with the built-in cabinet and use a freestanding refrigerator in the niche instead. After removal, there is about exactly 60 cm (24 inches) of space available. Question: will a freestanding refrigerator with a width of 60 cm (24 inches) fit there, including door clearance?
Thanks and best regards, Ashley
hampshire24 Jun 2018 16:12It depends on the door opening mechanism.
If you have a kitchen that is open to the living area, keep in mind that freestanding appliances are generally somewhat noisier than built-in appliances.
Freestanding refrigerators usually have door hinges designed for both sides, so the door swing can be adjusted as needed. Freestanding units can also be slightly smaller than built-in refrigerators; mine measures 547mm wide by 558mm deep (21.5 inches by 22 inches).
Depending on whether suitable end panels are available for the kitchen, I would recommend removing the old refrigerator cabinet altogether. This looks better, and a freestanding refrigerator also uses less electricity because heat dissipation is more efficient.
ashley schrieb:
Now we want to remove the refrigerator along with the built-in cabinet and use a freestanding fridge in the niche. That’s exactly what he wants, to remove the old built-in cabinet. However, since there are cabinets on both sides, the opening mechanism of the freestanding fridge needs to be taken into account.
