ᐅ Floor plan with a basement on a sloped site
Created on: 13 Aug 2015 22:29
Watcher78
Hello dear forum members,
I would like to ask you to review the floor plan. The elevations are not included yet because we want to first confirm with the builder that the design is heading in the right direction. We quite like the floor plan so far. We want a large open living and dining area. The kitchen could be a bit narrow and it might be difficult to arrange kitchen units like tall cabinets. Therefore, the entrance to the pantry should be moved.
The current house design is quite solid: no dormer, and a floor plan of 9m x 11m (30ft x 36ft). The knee wall is 1.40m (4.6ft) high with a gable roof pitched at 45 degrees. Possibly, in the upper floor, a space-saving staircase will be installed instead of a pull-down attic ladder.
The roof ridge runs from southwest to northeast. The floor plan is oriented to the northeast. We are planning a terrace facing southwest and a balcony at the back measuring 5m x 3m (16ft x 10ft) on stilts with a wide view over the fields.
In the basement, a utility room, two additional living rooms, and a toilet are planned. Due to the sloped site, the basement will have two large windows facing northeast. The layout of the basement rooms is not yet final. It will be a living basement including underfloor heating.
We would like to mirror the floor plan horizontally. We think orienting the living/dining area toward the south or southwest would be better than the current orientation to southwest/northwest.
The garage is still in the planning stage. Currently, a double garage is shown, but it may be reduced to a single garage.
Development plan/restrictions
Plot size: 650 m² (7,000 sq ft)
Slope: yes, running from southwest to northeast
Site coverage ratio (floor space index): 0.3
Building envelope, building line, and boundaries
No adjoining development at the property edges
Number of parking spaces: 1–2
Number of floors: 2
Roof type: gable roof
Style: standard
Roof ridge orientation: southwest to northeast
Owners’ requirements
Basement: yes, living basement
Number of occupants: 2–4
Space needs: Ground floor living and dining, upper floor sleeping, basement guest rooms + other rooms
Open kitchen separated by sliding door
Seating for 6–8 people
Fireplace: yes
Balcony, roof terrace: terrace to the northeast
Garage, carport: planned later
Other wishes/special features/daily routine: front terrace facing southwest
Planner: planner from a construction company
What we like: large living/dining area, also quite wide
What we don’t like: kitchen and pantry too narrow, difficult to furnish
We look forward to your suggestions and feedback.
Grundrissplan eines Hauses mit Wohnzimmer, Küche, Bad und Balkon
Grundrissplan eines Hauses mit Küche, Essbereich, Wohnzimmer und Treppe.
Grundriss eines Hauses mit Balkon, Treppenhaus und Zimmern im Obergeschoss
Grundrissplan des Obergeschosses mit Schlafzimmer, Kinderzimmer, Bad und Diele.
Doc.Schnaggls
4 Sep 2015 13:21
Hm, you could mount the TV on the back panel of a proper built-in cabinet and also place the connection outlets within that back panel.
I would keep the shower where it is now—just move the shower entrance toward the back, in the direction of the bathtub, and position the showerhead on the front wall facing the hallway.
A knee wall height of 1.40 m (4 ft 7 in) should be sufficient—that’s the height of ours as well.
Overall, I really like the floor plan.
One thing to consider might be making the sliding door between the kitchen and dining area twice as wide, so you can both visually connect and separate the rooms.
On the ground floor, however, we avoided doors completely (except for the pantry and guest bathroom), as I’m a big fan of open spaces.
Watcher78
4 Sep 2015 13:39
Ah, okay, thanks, now I understand the wardrobe situation 🙂.
I also see the dormer as a good alternative, and then place both children’s rooms at the front.
The shower idea is good as well. I will include that in the next version.
I’ve slightly modified the upper floor plan. The question is whether the children’s rooms are still large enough. With the given floor area, the sloped ceiling needs to be excluded. But adding a dormer provides a bit more space.
What do you think?
2D floor plan of an upper floor with rooms, hallway, and bathroom
Watcher78
4 Sep 2015 17:03
Is my idea really that bad? 😉
kbt09
4 Sep 2015 17:06
I don’t understand the reason behind your changes.
Comparison:
Tommes78
4 Sep 2015 17:43
The idea is that you don’t have to go through the walk-in closet to get to the bedroom. At the same time, the bedroom is enlarged so that a dresser can be placed along the right wall.
kbt09
4 Sep 2015 17:53
However, the person who gets up earlier has to go through the dressing room first and then back through the bedroom (disruption) to reach the bathroom.
