ᐅ Floor plan for a new single-family house, 1.5 stories, 148 m² (approximately 1,593 sq ft)
Created on: 24 Aug 2020 08:33
Rampelzampel
Plot size: 766m² (width at the street 20.5m (67 feet))/ No. 28, drawing oriented to the north
Slope: none
Site coverage ratio: 0.4
Floor area ratio: II
Edge development: no
Number of stories: 1.5 or 2
Roof type: gable or hip roof
Architectural style: modern
Orientation:
Maximum heights/limits: ridge height 9.5m (31 feet), eaves height 6.5m (21 feet)
Additional requirements: rainwater infiltration on site
Homeowner Requirements
Architectural style, roof type, building type: 1.5 stories with minimum 1.60m (5 feet 3 inches) knee wall or urban villa
Basement, floors: no basement, 1.5-2 floors
Number of occupants, ages: 2 adults aged 27 and 33, 1 child planned
Space requirements ground floor, upper floor: about 75m² (800 sq ft) each
Office: family use
Guest overnight stays per year: 10
Open or closed layout: open living-dining area preferred
Open kitchen, cooking island: yes, preferred but not mandatory
Number of dining seats: 6-8 (daily need is 4 seats)
Fireplace: no
Music/sound wall: no
Balcony or roof terrace: no
Garage, carport: 1 garage with annex, 1 carport
Further wishes/special features/daily routine, also explanations why certain things are desired or not: none
Planner: combination of builder and self-designed
What do you particularly like? Why? We are very satisfied with the upper floor, especially regarding the room layout and sizes. An L-shape for the living-dining area on the ground floor is preferred.
What do you dislike? Why? I am still uncertain about the ground floor because the study is also intended as a guest room; it seems a bit small for that purpose, although a 1.40m (55 inch) pull-out couch would likely fit.
Cost estimate according to architect/planner: 275,000
Personal budget limit for the house, including equipment: 300,000
Preferred heating technology: air-to-water heat pump or ground-source heat pump
If you had to give up something, on which details/upgrades
- could you do without:
- could you not do without: staircase not directly at the front door, ground floor shower
We have visited many model homes and construction companies, sought advice, and usually returned to a floor plan like this because we wanted an additional guest/office room on the ground floor. We saw the upper floor almost exactly as drawn in a model home and only enlarged the bathroom slightly and shifted the dressing room a little.
So, I hope I’ve filled in the most important details first. I am open to any changes; as mentioned, the L-shape in the living-dining area should be maintained.
What still concerns me somewhat is the placement of the possible outdoor unit for the air-to-water heat pump, which according to the development plan must be at least 10m (33 feet) from the nearest neighbor; with the current plan it would be directly in front of the house or beside the carport.
After a long selection process and several offers, we are currently favoring Gussek Haus, Helma, and Elbe-Haus, which could realize the house roughly within the budget. The tendency currently leans towards Gussek Haus because although it is a prefab house, we like the hybrid wall and the clinker brick exterior well, and the price-performance ratio fits. But nothing is decided yet; the plot will be developed at the beginning of next year and construction will start from summer 2021.
Floor plan of a house: living/dining, kitchen, hallway, office, utility room and shower/WC.
Upper floor plan: bedroom, dressing room, 2 children's rooms, corridor, bathroom, storage room, staircase
Site plan of a development area with plots and area information in square meters
11ant25 Aug 2020 13:15
I'll take this as a suggestion to consider frosted stairwell windows.
Rampelzampel
25 Aug 2020 14:15
I have thought about that as well, but somehow I like the idea of having a large window by the staircase. Is it more practical to use frosted glass directly to prevent seeing through, or is it better to apply a film that can be changed later if I want to alter the look or remove it if I don’t like it?
Pinky030125 Aug 2020 14:23
I would use a membrane, as it offers more flexibility. For example, we had a half-height membrane in the kitchen. There are also different levels of transparency and patterns available.
11ant25 Aug 2020 14:28
For example, vehicle and storefront graphic specialists could create frosted window film with a custom design, which could also include the house number if desired.
OWLer25 Aug 2020 14:35
The question is how often you walk down the stairs naked. The recommendation is to plan for Venetian blinds there. You can open them slightly to let in light while making it almost impossible to see inside during the day.
Rampelzampel
25 Aug 2020 14:41
@11ant
Also a good idea, I will keep it in mind.
@OWLer
I need to check if the manufacturer can do that for such a tall window. Possibly also a pleated blind to cover as high as you can reach.
Maybe it won’t be necessary if we redesign the house and move the staircase elsewhere. But thanks for the ideas.
