ᐅ The floor plan "HOUSE FOR TWO" covers approximately 150 sqm and is introduced here.
Created on: 3 Jul 2020 13:23
pagoni2020
So – now I’m presenting our “House Project for Two” expecting your honest and maybe harsh feedback. Don’t hold back, as I can only benefit from it.
The building permit / planning permission application is currently being submitted, and preliminary information suggests it should be approved. We deliberately avoided too many deviations from the very old development plan.
We like a modern, minimalist architectural style. The floor plan is a mix of our own living habits, our existing furniture including the kitchen, and the budget, since at this stage of life we don’t want to take on risky debt.
Our current condominium is very stylish and was just recently customized by ourselves, but life changes; besides, we want to be able to have a small fire in our own garden again.
We are now building with a general contractor (GC) who has a good reputation and has already allowed us to change many things without stress – so far. Ideally, we would have built with an independent architect or our friend who is an interior architect, which would have given us more freedom in choosing trades, but this time we want to focus more on details and avoid the running around that happened the first time, 30 years ago. No, this time I won’t be digging foundations or pouring the basement myself until my family doesn’t recognize me anymore.
Whether it will be a garage, carport, or parking space depends on the costs, as does the attached balcony, which would then be a so-called standing balcony; initially, it just needs to be approved. There will also be a larger garden house with an outdoor sauna.
The plot is quite large and has a nice view of greenery. Unfortunately, only to the north, about 500 m (1600 ft) away and at a lower level, there is a beautiful lake. For this reason alone, we decided not to build a bungalow, since having a lake view and not using it was out of the question (hence the “emergency balcony” at the bedroom). Originally, a house with a bend was planned, but it always looked ugly in the end.
HOUSE FOR TWO
Plot size: 1400 sqm (15,000 sq ft)
Slope: No
Number of floors: 1.5
Roof type: Gable roof
Architectural style: modern-minimalist
Client requirements
Style, roof type, building type: clean lines
Basement, floors: no basement
Number of occupants, age: 2 (one of them still works a bit more…)
Guest stays per year: quite often, alternating
Conservative or modern construction: modern, open plan
Number of dining seats: 4
Fireplace: yes/no/undecided, possibly also gas fireplace
Balcony, roof terrace: possibly a balcony at the bedroom for lake view
Garage, carport: yes, depending on price
Additional wishes, etc.:
Separate guest area, possibly as a bedroom in old age, then guests upstairs
Custom furniture and kitchen integrated
Separate TV area from the gallery, next to it a separate relaxation area with recliner
Kitchen with 120 cm (47 inch) side-by-side refrigerator or 70 cm (28 inch) refrigerator by the window side
Monolithic Rock XL1 wood stove available, chimney planned outside for lower costs, appearance, and less space inside
Ground floor window areas separated by masonry walls due to chimney, possibly refrigerator placement but especially due to manufacturer’s limited width (according to GC)
Original idea was continuous window surfaces up to the eaves in living/dining area, now separated at ceiling height by masonry strip
Some parts in the plan/floor plan not labeled correctly yet (GC design implementation)
House design, who designed it: by the clients + partial coordination with interior architect, currently executed by a builder’s planner
What do you like most and why?
Simple architectural style, gallery, spacious window surfaces, external blinds, open layout
What don’t you like and why? I’m sure I’ll read about it here
Estimated price according to architect/planner: -
Features: The goal is to invest selectively and sensibly but consistently omit unnecessary, cost-driving frills (in my opinion)
Preferred heating system: undecided, unfortunately no gas connection available
If you had to skip something, which details or extensions could you do without? Maybe the fireplace… I’m still unsure about the location, I would like a built-in gas fireplace under the stairs, but only for that would we get a liquefied gas tank?
Why is the design the way it is? For example:
Own life circumstances, existing furniture, individual living habits
I welcome direct and constructive assessments. The building shape and location of carport/garage are fixed. The focus of questions is on layout details and usage/design options.
There will be a glass roof or slatted shading in front of the kitchen area.
The plot is almost flat, and the outdoor area will be simple and user-friendly, with a larger garden house including outdoor sauna, storage for gadgets, tools, etc.
Grundriss eines Grundstücksplans mit zwei grauen Gebäuden und Maßangaben.
Grundriss eines Apartments: Wohnzimmer/Essen, Küche, Schlafzimmer, Bad, Diele, Gästezimmer.
Grundriss eines Hauses: Schlafzimmer mit Bett, Bad/WC, Treppe und Galerie.
Modernes Haus mit dunkler Fassade, Satteldach, linke Garage und rechte Glasfront mit Sofa.
Modernes zweistöckiges Haus mit dunklem Dach, Glasfronten, Terrasse und Anbau.
Tarnari3 Jul 2020 20:07
Then the round of criticism should be over by now... a bit late, I’d say... or are you masochistic?
I thought the same, but since I don’t know much about it, I kept quiet.
Isn’t it true that after submitting the building permit application (or after its approval), you can’t just overturn everything without having to reapply completely?
We also made changes after the application. But these were all quite minor things, like removing the window in the utility room because we later realized that with all the technical equipment, the entire wall is needed. Things like that. But for real changes that might affect structural aspects, can you just do those afterwards without any further approval?
pagoni2020
3 Jul 2020 20:11
Then the critique round should be over... a bit late, I’d say... or are you masochistic by nature?
Until now, I didn’t know I might be that way, but maybe there is still potential for development in me.
Don’t worry, I can still change the things that are not finalized; I have only pointed out what is already confirmed.
pagoni2020
3 Jul 2020 20:16
@Tarnari
You don’t have to keep quiet because of me, go ahead and say whatever you want; I don’t claim to be infallible.
As you wrote, this applies AFTER the building permit / planning permission is granted.
As I mentioned, the design still has to go through the structural engineering phase.
I’m not necessarily early with this, but not too late for what I still want. I’m not too worried about making adjustments afterward; I’m used to that with myself. I also take responsibility for the consequences and always look for the cause within myself.
But thanks for the information anyway!
Solveigh
3 Jul 2020 20:31
What are the arguments against installing a proper passenger elevator that could be added later if needed? You would only need to reserve space on each floor in the current design, which could later be converted into a shaft. Today, overhead clearance and a pit are no longer necessary.
We also swapped the floors because of the view, but the option to install an elevator was a prerequisite.
Another point to consider is the possible lack of direct access from the top (living) floor to the garden, which is something you have to be okay with!
Is there a picture of the “view” available somewhere?
Tarnari3 Jul 2020 21:01
pagoni2020 schrieb:
@Tarnari
You don’t have to keep quiet because of me, feel free to say whatever; I don’t claim to be infallible.
As you wrote, this applies AFTER the building permit/planning permission is granted.
I’m not necessarily early in the process, but not too late for the changes I still want. I’m not too worried about later adjustments; that’s just how I am. I take responsibility for the consequences and always look for the cause within myself.
Then I must have misunderstood; I thought the final building permit/planning permission application had already been submitted.
haydee
3 Jul 2020 21:16
@pagoni2020
Equality was invented to protect you men from making mistakes.
