ᐅ Floating parquet flooring transition to tiles
Created on: 7 Jan 2021 12:06
Sinovia
we have two transitions from hardwood flooring to tiles: one at the fireplace and one between the living room and kitchen.
The hardwood moves about 5mm (0.2 inches) up and down at the edges, especially near the kitchen. At the fireplace, I used liquid cork for the joint. This is now coming loose due to the movement. How can I secure the hardwood to achieve a durable solution?
Thank you very much!
Sina
Left side gray tiles, right side wood floor; narrow edge in between.
Metal door threshold between gray concrete floor on the left and wood floor on the right.
Rusty metal edge separates concrete floor (left) from wood floor (right), rust stains visible.
KlaRa7 Jan 2021 15:15
Sinovia schrieb:
There is also underfloor heating...
That would not be a problem even with screw fastening (using anchors). On one hand, the heating elements are at least 40mm (1.5 inches) below the top edge of the screed, and on the other hand, you would first use an appropriate detection device (or if available, a thermal imaging camera) to locate the heating elements. Otherwise, bonding the base profile is generally a secure method!
Sinovia
7 Jan 2021 18:32
Thank you very much for the detailed answers!
X
X_SH5_X
27 Jan 2021 14:19
@Sinovia: Have you installed a transition strip by now? At the beginning, I also didn’t install any tracks. I had an expansion joint between parquet and parquet. Like in your case, the whole area is a bit flexible. We once filled the gap with silicone, but in the end, the joint cracked and didn’t look good.
In the end, I bought a self-adhesive transition profile. It’s only been a few days, but it was easy to install without much drilling and has held so far. Probably a screwed-on profile would be better and more durable, but I’m satisfied with the self-adhesive option up to now.
For the tile-to-parquet transitions, we also filled the gaps with silicone, and that has held up very well. This is probably because the tiles in that area don’t move and are rigid.
