ᐅ Flat roof warranty expired – what to do or do nothing?
Created on: 17 Nov 2019 16:08
HilfeHilfe
Hello, neighbors of ours have serious problems with their flat roof within the warranty period. In some areas, the wood underneath the PVC layer is rotted or decayed, and the wood comes apart by hand. The issue is now being handled by an expert who partially sank during the roof inspection. Our roof is older, built by other tradespeople (same general contractor) and just outside the warranty period. I was on the roof today and didn’t notice anything; I tested it a bit by applying pressure. Does it still make sense to get an expert for safety, even though we are about 4 months past the warranty period? Attached is a photo.
Grau betonierter Boden mit Fugen, die ein Kreuz bilden; ein kleiner weißer Fleck
Flaches Beton-Dach mit zwei schwarzen Stützen auf Bodenplatten; Fugen und Rinnen sichtbar.
hampshire
20 Nov 2019 17:46
We designed the central part of our timber house with a flat roof – including gravel and green roofing. The beam spacing is naturally tighter and stronger, which does add some extra cost, as with anything that improves structural stability. It’s not the “wood” material itself, but the construction method that matters.
Dr Hix22 Nov 2019 11:06
Try entering the term "self-composting flat roof" into the search engine of your choice.
Hausbau2019
19 Jan 2020 08:11
HilfeHilfe schrieb:
Well, basically we are satisfied. We also don’t see any mold or stains, etc.
We know that a flat roof isn’t the ultimate solution, and the same goes for the wood.
So we will just save up even more money.
I hope we can hold out for 15 years.
Man, HilfeHilfe, now I’m really surprised. From your posts, I assumed you were wallpapering your walls with 100-dollar bills. At least that’s the impression you get when others say the budget might get tight.
HilfeHilfe
19 Jan 2020 21:19
Hausbau2019 schrieb:
Wow HilfeHilfe, I’m really surprised. From your posts, I assumed you were wallpapering your walls with 100-euro bills. At least that’s the impression I got when others said the budget might be tight.
Of course, I have the money to wallpaper with that.
hampshire
19 Jan 2020 23:09
HilfeHilfe schrieb:
Logically, I have the money to use for wallpapering
It's not as expensive as you might think. Less than €90 per square meter with one-dollar bills.
HilfeHilfe
20 Jan 2020 06:28
hampshire schrieb:
It’s not as expensive as you might think. Under €90 per square meter (about $1 per sq ft).
Correct. But I chose pounds instead. They match the furniture colors better. I don’t pay much attention to money... appearance is what matters.
