ᐅ Flat roof warranty expired – what to do or do nothing?
Created on: 17 Nov 2019 16:08
HilfeHilfe
Hello, neighbors of ours have serious problems with their flat roof within the warranty period. In some areas, the wood underneath the PVC layer is rotted or decayed, and the wood comes apart by hand. The issue is now being handled by an expert who partially sank during the roof inspection. Our roof is older, built by other tradespeople (same general contractor) and just outside the warranty period. I was on the roof today and didn’t notice anything; I tested it a bit by applying pressure. Does it still make sense to get an expert for safety, even though we are about 4 months past the warranty period? Attached is a photo.
Grau betonierter Boden mit Fugen, die ein Kreuz bilden; ein kleiner weißer Fleck
Flaches Beton-Dach mit zwei schwarzen Stützen auf Bodenplatten; Fugen und Rinnen sichtbar.
guckuck2
20 Jan 2020 07:14
HilfeHilfe schrieb:
Correct. But I decided on pounds. They match the furniture colors better. Not really focusing on the cost... appearance is what matters.
Others also have pictures of women on their walls, so why not Ellie 2nd. Tastes are different after all.
Hausbau2019
20 Jan 2020 09:17
HilfeHilfe schrieb:
Correct. But I decided to go with pounds. They match the furniture colors better. Not really watching the budget... appearance is what matters.
You must have taken that idea from KlausiMausi. But true, what else would you use them for—wallpapering or lighting the fireplace? By the way, they work great for that.
tumaa
20 Jan 2020 09:21
Are you currently playing Monopoly?!
= wake up
HilfeHilfe
20 Jan 2020 10:20
Hausbau2019 schrieb:
You must have copied that from KlausiMausi. But you're right, what else would you do with it? Wallpapering or lighting the fireplace works perfectly, by the way.
I prefer the Zlukis. They light better.
halmi
26 Feb 2020 10:05
I just came across this topic. What was the outcome here? Dr. Hix mentioned what I believe is the correct keyword 1-2 pages earlier.
HilfeHilfe
27 Feb 2020 06:29
All good, our roof was built differently and everything at the top is fine.
