finally, we can share our initial planning stages for discussion. We are still in the conceptual phase because, for us, it was first about determining whether the plot is suitable for our ideas. Therefore, no contract has been signed yet. However, we definitely want to continue working with the architect.
The reason for the "preliminary investigation" with the architect was that the plot has a few restrictions that need to be considered in the design and might have been dealbreakers for some buyers. These are:
- The large row housing development to the west with fixed building heights of 10.5 m (35 ft) for the full floors and 13.5 m (44 ft) for the final attic floor. These heights must be strictly observed. The distance between our house edge and the row housing edge is 16 m (52 ft).
- The fact that it is a sloping plot with a 3 m (10 ft) gradient from southwest to north.
The discussion about the plot itself already took place here: https://www.hausbau-forum.de/threads/Grundstück-die-zweite-Hilfe-bei-der-Beurteilung.30148/
We concluded that we are comfortable with the purchase and the possibilities the plot offers. Compared to other plots, it has its own unique charms.
Further general remarks on the design:
Plot size: 502 sqm (5400 sqft)
Slope: Yes, sloped. Approx. 3 m (10 ft) height difference from southwest to north
Floor area ratio (FAR): 0.4
Plot ratio: 0.8
Building window, building line, and boundary: See excerpt from development plan (map oriented north)
Number of parking spaces: 1.5 per residential unit
Maximum possible residential units: 2
Number of floors: 2 full floors allowed, attic floor not allowed
Roof style: pitched roof and flat roof allowed
Orientation: no specifications
Maximum heights/limits: Residential building height max. 6.5 m (21 ft) and max. 10.5 m (35 ft) total building height measured from top of access road in the northeast
Further requirements: Garages/carports only allowed within the building window or the designated yellow-marked areas
Style, roof type, building type: Bauhaus, flat roof -> Ideally, we want to incorporate the Bauhaus style with some authentic elements and base the concept accordingly. We can also imagine a minimalist pitched roof.
Basement, floors: Basement (KG), ground floor (EG), and upper floor (OG)
Number and age of occupants: 29 + 28 + 1 year old. It would be nice if we could be four in the future.
Room requirements, ground floor and upper floor: Together approximately +/- 170 sqm (1830 sqft) of living space
Office: We definitely need an office.
Guest sleepers per year: 3-4
Open or closed architecture: We are generally fans of open architecture.
Conservative or modern construction: modern construction
Open kitchen, kitchen island: Yes, an open kitchen with a kitchen island would be our ideal choice.
Number of dining seats: 6-12
Fireplace: No
Music/stereo wall: There should definitely be space for a 5.1 sound system.
Balcony, roof terrace: Not strictly necessary. However, we had the idea of adding a small roof terrace with filtered facade elements as privacy screens (this is reflected in our version of the room program). Inspired by the idea of a windowless house with interior courtyards in parts.
Garage, carport: Carport
Additional wishes:
Who designed it: Concept from the architect and alternative versions of the room program from us.
What do you like most? Why? Split-level and open void space that reflect the idea of building with the terrain and having two terraces protected by pergolas with access to upper and lower levels. We also like that it is possible to walk all around the house. The open void keeps it airy and creates a continuous sightline upwards that could be closed with a skylight, for example. The volume was deliberately placed on the western edge of the building window, even though this brings it closer to the row housing, to enable a more sheltered terrace to the east. Because to the east, there are only garden plots and a narrow access road that is not intended as a main access.
What do you dislike? Why? Room layout: basically too small and difficult-to-use room arrangement. We are reluctant to give up the split-level because it carries the idea of working with the terrain and provides access to the lower and upper areas. On the other hand, it consumes space and functionality. The same applies to a potential open void above. Also, overall, the rooms are too small, especially given that there should be quite a bit of space available with 170 sqm (1830 sqft) of living area.
Price estimate according to architect/planner: No detailed cost breakdown by work stages yet. However, we provided our budget and the concept was developed based on the assessment that it was feasible.
Personal price limit for the house, including equipment: maximum $625,000
Preferred heating technology: Geothermal
If You Have to Give Up Something, on which details/extensions
-can you give up: Although reluctantly, if necessary, on controlled ventilation, home automation, and geothermal heating.
-can you not give up: External blinds, a garden on the east side as a protected area for dining and relaxing since the front street is not the main access road and should be screened accordingly with planting.
What is the Most Important/Basic Question About the Floor Plan in 130 Characters?
We obviously want honest opinions on our project to get ideas on what to consider and especially how to improve things. We currently find it difficult to judge the room sizes and layout. We are looking for ideas on how to improve without straying from the core concept.
[IMG alt="OG.jpg"]https://www.hausbau-forum.de/data/attachments/34/34245-1dba1bcffe9276a24d7771734e7f8356.jpg[/IMG]
[IMG alt="EG_KG.jpg"]https://www.hausbau-forum.de/data/attachments/34/34246-c4723bc5436c3067eb0d370cb371b16a.jpg[/IMG]
- Before discussing the design from the architect’s concept, it is important to know that the main focus was, as mentioned, to present the fundamental idea, positioning, and exterior shell. Accordingly, the room layout was secondary. So far, windows and similar details are completely missing.
- Access to the basement is provided via the split-level in the design. However, this will definitely be solved by the main staircase. This was proposed as well.
Plot ratio: 0.8
Fireplace: No
Additional wishes:
- Use of controlled residential ventilation
- External blinds / shutters
- Use of home automation system (e.g. KNX or Free@Home)
haydee schrieb:
Basement level with a mini pseudo-living area
Kitchen and dining in the basement level
Stairs stacked on top of each other
Remove the open space on the upper floor, put a proper bathroom upstairs
Possibly a proper split level
There is too much focus on design and too little on function here.
Mini kitchen
Mini bathroom – reminds me of the bathroom in my first 45m² (484 sq ft) apartmentExactly: The living room doesn’t need garden access. It’s used in the evening for sitting in front of the TV.
Dining and kitchen with garden access; your upper floor option is more plausible.
And check the ratio of room size to open space. The guest room is only 8m² (86 sq ft), but there is a lot of hallway and open space.
haydee schrieb:
Garden level with a small pseudo-living area
Kitchen and dining on the garden level
Stairs stacked above each other
Remove the open space on the upper floor, real bathroom upstairs
Possibly a real split level
There’s too much focus on design and too little on function here.
Tiny kitchen
Tiny bathroom – reminds me of the bathroom in my first 45 m (147 ft)² apartment Thanks to you as well.
I understand your points. But could you briefly explain again how you would approach or roughly envision it in our case if the kitchen and dining area were to be placed on the garden level?
It would be hard to plan anything that misses the building envelope more than this. After subtracting the two side setback areas, your buildable space could make anyone wanting a spacious suburban villa envious—and yet you are planning exactly the opposite: a floor plan more typical for infill plots in villages or historic urban gaps, where the lots were divided without any land consolidation process. Apart from the rotation of the house’s orientation, this narrowness has come about simply because you are stepping the house back from its full "width" (in terms of its north-south extension) by the depth of the terrace, instead of gaining depth by adding at least an "L"-shaped wing beside it. This forces an unfavorable internal layout along the elongated axis: large circulation areas and therefore long walking distances, similar to a row house the length of a towel.
At the end of the bowling-alley-like corridor lies a "living room" that can’t decide what it wants to be: either a ridiculously small 8 m² (86 sq ft) terrace-door vestibule or a two-story hall at the same time. It’s neither fish nor fowl, neither one thing nor the other. If it were drawn furnished, you’d clearly notice how tiny it actually is. The lower half of this living area also serves as an access point to the utility cellar. You haven’t just started here yesterday—you really can’t have taken this design seriously. Even if I were on vacation or sick this week, it must have been obvious to you that no praise would come from this.
Follow your plot, honor its unusually comfortable building envelope for the current market, and don’t turn the building unnecessarily sideways. There is plenty of potential to develop something beautiful here, but for heaven’s sake, don’t carry over a single detail from this design into the next one—not just the kitchen, and certainly not the “structure” that arranges the rooms as if the house were an addition on top of row garages.
As a precaution, @kaho674: let the original poster do their own tinkering first.
hampshire29 May 2019 07:10The building concept is clearly organized and well divided into different living areas. I really like it – with a few minor issues that should be addressed.
Upper floor: My favorite option is the one without an open space above the dining area, where the children’s rooms are accessed via a shared open play area. Building the walk-in closet with wardrobes without adding a wall is a smart way to save space. Unfortunately, the bathroom is far too small. If the staircase is moved toward the walk-in closet and the children’s rooms are slightly shortened, more room can be created for a larger bathroom.
Ground floor: I really like the central kitchen-dining area and the omission of a hallway. The wardrobe is out of sight, although it is rather small. The study/guest room is tiny and will need to be carefully furnished to work well. The guest toilet is also very compact. Some space could be gained by making the kitchen-dining area a bit narrower. With large window areas, the open space above the dining area is completely unnecessary. The division into two living areas is unusual but practical. I’m familiar with this from many American homes (which are usually much larger). The upper living area will likely be used more during the day.
Garden level:
The lower living area works well as a retreat and is suitable for guests when it gets a bit noisier. Since all the other rooms on this level also have external access, nothing needs to be carried through the lower living room.
I can well imagine living in a house like this. Only the study and the wet rooms feel a bit too small for my taste. Because of this, it’s not really a house to “grow old in” – although maybe it doesn’t have to be.
Garden level:
@hampshire
In the USA, larger houses often have multiple living areas.
Here you have very small rooms:
bathroom, kitchen, living room, office, cloakroom.
Where is there space for a sofa?
Retreat areas with open space on each floor.
On the sleeping level, you can hear the TV from the garden room.
Garden Level
Kitchen, Dining
Elimination of at least one basement/storage room
Ground Floor
Living Area
Leave open space (void)
Guest/office room larger
Wardrobe/closet larger
Possibly a small storage room (to compensate for the lost basement/storage room)
Upper Floor
Omit open space (void)
Bathroom reasonably sized – it is your family bathroom and should fit at least two people, as well as towels and toiletries
Possibly a gallery with a play area or later a reading nook
or a small utility room, as laundry will be done there
Kitchen, Dining
Ground Floor
Living Area
Upper Floor
