ᐅ First draft of the floor plan for a 150 m² house
Created on: 20 Feb 2017 21:53
Goldi09111
Today we have our first draft to present and would like to hear your opinions on it.
I won’t add any further comments for now and will let the two floor plans speak for themselves.
Thank you
Goldi
Ground plan of a single-family house with living area, kitchen, guest room, hallway, and garage
2D floor plan of a house with bedroom, children's rooms, bathroom, hallway, and stairs
Goldi09111
23 Feb 2017 09:03
The background of the planning is that there is already an informal approval from the building authority, as several houses in the development were built not according to the zoning plan. Therefore, we will apply for a special permit (not sure of the exact term).
23 Feb 2017 10:10
That naturally explains the situation.
Best regards in brief
11ant23 Feb 2017 13:14
If in the end, two out of nine builders are granted an exception permit, there is actually no need to establish a development plan at all. But well, for the beneficiary, it’s okay anyway. :-)
Goldi09111
23 Feb 2017 18:00
Exactly 🙂
Goldi09111
8 Mar 2017 21:45
Before creating a new topic, I want to take this opportunity here.
Our architect is currently designing the entire upper floor using drywall construction. However, I’m not entirely sure if this is the best choice regarding sound insulation. I have read various opinions but couldn’t find any conclusive information.
Is a 12.5mm (0.5 inch) drywall partition better than a 17.5cm (7 inch) solid wall? What are the additional costs for a solid wall? Isn’t it just the plaster?
What type of bricks are used in a 17.5cm (7 inch) wall?
How do the sound insulation values compare between drywall (double-layered) and solid walls?
For example, 40dB versus 50dB.
One possible advantage of drywall I see is potential savings through doing part of the work yourself.
RobsonMKK8 Mar 2017 21:48
Goldi09111 schrieb:
It’s just the plaster, right?
No, the block is 17.5cm (7 inches), then the plaster is applied.
Goldi09111 schrieb:
What kind of bricks are used for a 17.5cm (7 inches) wall?
Ytong, Poroton, sand-lime bricks... it depends.
Goldi09111 schrieb:
What are the soundproofing values for drywall (double-layered) versus solid walls?
It depends on the block type; you can’t generalize.
