ᐅ First draft of the floor plan for a 150 m² house
Created on: 20 Feb 2017 21:53
Goldi09111
Today we have our first draft to present and would like to hear your opinions on it.
I won’t add any further comments for now and will let the two floor plans speak for themselves.
Thank you
Goldi
Ground plan of a single-family house with living area, kitchen, guest room, hallway, and garage
2D floor plan of a house with bedroom, children's rooms, bathroom, hallway, and stairs
Goldi09111
8 Mar 2017 21:56
It was about additional costs concerning plastering.
We are building with Poroton T7.
11ant9 Mar 2017 01:09
Goldi09111 schrieb:
Our architect is currently designing the entire upper floor using drywall construction.
At first, I thought about roof slope connections, but if I remember correctly, your upper floor doesn’t have any sloped ceilings. However, many walls there are not aligned with the walls of the ground floor—so maybe there are structural reasons?
Goldi09111 schrieb:
I see the advantage of drywall construction possibly in cost savings through own labor.
The planner might have thought along similar lines, because...
Goldi09111 schrieb:
How much more expensive is a solid wall?
... you shouldn’t only consider the material costs: building interior walls properly with masonry, especially using the frequently applied smaller brick formats, is a more complex task. It requires time from experienced workers. Drywall partitions, as you already noticed with your idea of “own labor,” are much better suited for use by semi-skilled helpers. The cost of bricks is a secondary issue here, although sand-lime bricks (which avoid the need to tie interior walls into exterior walls) tend to be quite expensive compared to alternatives. Others have already elaborated more details.
By the way, “masonry” doesn’t necessarily mean 17.5cm (7 inches) thick walls everywhere; non-load-bearing walls with a thickness of one brick, about 11.5cm (4.5 inches), are also common.
