ᐅ Experiences with KALLAX back panels made of MDF instead of cardboard?
Created on: 20 Jun 2021 14:23
Anridra
I am planning to replace the standard cardboard back panels on my KALLAX shelf unit with MDF panels. My main motivation is the significantly better stability and durability that MDF is supposed to provide, especially if the shelf is moved frequently or subjected to heavier loads. However, I am unsure about the specific advantages and disadvantages I might face by switching to MDF.
Has anyone had experience with MDF back panels on KALLAX units? How does the installation, weight, and load capacity compare to the regular cardboard back panels? Does the shelf remain stable in the end? And are there aspects like moisture sensitivity or visual differences that should be considered?
I would be very grateful for your assessments, tips, or any warnings about potential issues.
GUSTAVO5621 Jun 2021 14:56kulau schrieb:
One more question: Are you planning to use the shelf only as a static unit, or will it be moved or transported as well?This is essential. Although MDF back panels increase the overall stability of the unit, they can quickly become a weak point during transport or frequent repositioning because MDF has lower bending strength under impact compared to cardboard.
In general: when cutting, work precisely to the edge because protruding edges are easily damaged. When fastening individual parts with screws, use spacer strips so the MDF does not sit directly against the surface and the screws maintain their load-bearing capacity.
Regarding moisture: MDF back panels are very sensitive to moisture – even slightly increased humidity can cause swelling. In rooms with a normal indoor climate, this is usually not a problem, but I would strongly advise against using MDF in bathrooms or basements.
Why not also consider HDF tongue-and-groove panels? They are stable and lighter than MDF but more expensive and harder to work with.
If your shelf needs to withstand loads from heavy objects, MDF back panels are definitely superior. However, I would recommend adding a diagonal brace as well to further reduce the tipping moment.
GUSTAVO56 schrieb:
When cutting, work precisely on the edge since protruding edges can be easily damaged.Thanks, that’s an important tip. I plan to use the shelf in the living room, so it will be a relatively dry environment, and it will remain stationary. It will mainly hold books and decorative items, with no frequent moving.
LOGEMIN schrieb:
I generally recommend the MDF option for heavier loads.That fits well since I intend to load the shelf somewhat heavily. Could you also advise whether it’s best to paint the MDF before installation or only after assembly? Which approach offers the best protection without compromising the screw holding strength?
