ᐅ Experiences with Ground Source Heat Pumps
Created on: 23 Oct 2015 21:40
Saruss
here I would like to share some experiences and data regarding my brine heat pump and deep drilling, based in part on the expert’s "questionnaire":
a) What is the soil composition on your property?
Up to 3m (10 feet) silty, fine sandy, clayey soil
Up to 4m (13 feet) slope debris, rock fragments
Then bedrock (mainly limestone)
b) How deep was the drilling?
Drilled twice to a depth of 72m (236 feet)
c) How much did the drilling cost?
€10,400 including double U-probes DN25
Grouting material with 2.0 W/mK thermal conductivity
Permitting process (building permit / planning permission)
Pressure-tight house entry at the basement and underground routing of supply lines (about 25m (82 feet))
Filling/draining equipment, filling, pressure testing, etc. (all inclusive)
d) How much did the system cost?
System: Tecalor TTc 05 with heating output at B0/W35 of 5.8 kW and coefficient of performance (COP) of 4.8
Cost: €9,800
e) Were there any difficulties during installation, if so, what kind?
Because the water used to flush out the drilled material during drilling seeped away, a "small compressor" was needed to blow it out with air. However, it had to be placed on a neighbor’s property who had not yet started building. The machine was the size and approximate weight of a 20-ton truck but was off-road capable. This caused a 2-day delay because the compressor first had to be transported to our site. No additional costs were charged.
f) How is the daily operation?
"Like a refrigerator." Once the parameters on the heating system are correctly set, the only thing that should be done is occasionally reading the information/data such as operating hours and source temperature. Otherwise, it runs "on its own," just like any heating system. When the door is closed, the unit is virtually inaudible. Very discreet since, apart from the cabinet in the utility room, nothing else is visible (all brine pipes are underground).
e) What are the operating costs for which living area?
Currently, a living area of 180sqm (1937 sqft) is heated, plus an additional 65sqm (700 sqft) of cellar space within the insulated thermal envelope (these rooms are around 15-16°C (59-61°F) on the coldest days). From September 2014 to September 2015, 2,000 kWh of electricity was consumed for heating and hot water (2 adults, 1 baby, 1 toddler). The house is a KfW-70 standard building according to the 2009 energy saving regulations, which already met the required technical standards before the central ventilation system with enthalpy heat exchanger was installed (we decided to add this after the initial applications).
f) to be continued ....
Note regarding the comparison of the coefficient of performance (COP):
Since optimizing the heating curve and settings at the end of last year, the system has had a COP of about 5.5. Operating hours are around 1200; the deep borehole was drilled approximately 20% deeper than initially recommended by the companies, at our own request.
Bookstar
21 Mar 2018 23:33
There is no BAFA funding available for new construction and air-source heat pumps, as the required values cannot be met.
andi28ffm
22 Mar 2018 06:12
Bookstar schrieb:
There is no Bafa subsidy for new builds with air source heat pumps, as the required performance values cannot be met.
I received a Bafa subsidy of 1500 euros innovation bonus for an air source heat pump. (IDM ipump A)
Mastermind1
22 Mar 2018 07:28
Bookstar schrieb:
There is no Bafa funding for new builds with air-source heat pumps because the required performance values cannot be achieved.
There is… but… Certain momentary measurements representing an annual performance factor count. Some air-source heat pumps do reach this. The problem is that the optimal temperature conditions for air-source heat pumps are not present throughout the entire year. Ground-source heat pumps perform better in this regard due to relatively constant ground temperatures year-round.
Bookstar
22 Mar 2018 17:43
There are also people who have won six-figure or higher amounts in the lottery—anything is possible...
Mastermind1
22 Mar 2018 17:56
Bookstar schrieb:
There are also people who have won six-figure or even higher amounts in the lottery, it’s all possible…
Well, your statement was actually clear – there is no funding for air-source heat pumps… To be clear, that is incorrect.
I haven’t counted the BAFA list of eligible air-source heat pumps, but I think at least 50 air-source heat pumps that qualify for funding (BAFA) are listed.
Bookstar
22 Mar 2018 18:00
These are only theoretically eligible for funding; you also have to meet the requirements, and this is where it usually fails...
